Connecting to test socket
- Connecting to test socket
- « Previous
- 1
- 2
- Next »
Re: Connecting to test socket
23-01-2013 5:42 PM
@ Chris,
OK, thanks.
@Anotherone,
think you're right. I'll just have to saw the window frame unfortunately
OK, thanks.
@Anotherone,
Message 16 of 21
(483 Views)
23-01-2013 5:50 PM
Can you post a pic of your master socket?
Message 17 of 21
(483 Views)
26-01-2013 9:44 PM
Quote from: AndyH Can you post a pic of your master socket?
Sorry Andy = don't quite know how I missed this. I'll see if I can do a picture but in the meantime I'll attempt an explanation: the socket is on a window ledge next to a hall window, with the base of the socket resting on the ledge. When double glazing was fitted the fitters put a new window sill in which went past the socket to a depth of just under half the socket, so they cut the sill around it and "joined" it with sealant on the front and side which meets the sill (an "L" shape). As a result when I unscrew the socket I can't slide the cover off as it's wedged into place by the sill. The only option I can see is to remove the offending section of sill, which will involve cutting it by around a centimeter or so. Since I failed carpentry 101 I'm afraid the result is going to look less than completely professional
Message 18 of 21
(483 Views)
26-01-2013 10:39 PM
Can you not get a blade/Stanley knife to cut the seal between the NT5e and sill, then force the front plate off?
Message 19 of 21
(483 Views)
26-01-2013 10:49 PM
already tried that. The sill's fairly tight against the box. I'm reluctant to apply too much pressure in case I break the box.
Message 20 of 21
(483 Views)
26-01-2013 11:05 PM
I know what I'd do.
Buy another box online (in case I broke the original) and "relocate" it.
Message 21 of 21
(483 Views)
- « Previous
- 1
- 2
- Next »
