Connecting 2 hubs to Plusnet router using same network
- Connecting 2 hubs to Plusnet router using same net...
04-12-2018 10:22 AM
Hi, I have a Plusnet hub router with two hubs connected with ethernet cables. I would like to use one wireless network to enable me to log on with one password for my iPads or mobile phones where ever I am throughout our house. However, the hubs will not connect when setup for an existing network and they only connect when setup for a new network. So I have to use 3 passwords! Any ideas how I can over come this?
Re: Connecting 2 hubs to Plusnet router using same network
04-12-2018 1:11 PM - edited 04-12-2018 1:12 PM
Are you trying to use one of the Hubs as a Wireless Access Point? - Just to send out a wireless signal.
EDIT: If you are read this post: https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138...
CJT
05-12-2018 11:31 AM
Hi @rshaines
I would suggest taking a look at the thread @CJT-80 linked as it would contain the relevant information if you were using a second Hub1.
If you are using any 3rd party hardware then I'm afraid we would not have the ability to assist on this matter, but I'm sure on of our Forum Members will have the require knowledge.
Kind Regards,
Alisdair
