Connected to gateway but not dns server
- Connected to gateway but not dns server
Re: Connected to gateway but not dns server
02-11-2015 8:58 PM
Well just use the url from the page where you are seeing the stats then See if Get Source yields any information with the numbers in.
02-11-2015 10:46 PM
Today's speeds have been between 0.69 and 1.15. Currently 0.80. Noise has been between 2.8 and 5.6
02-11-2015 10:53 PM
What time of day (approx) did that low 0.69 speed occur?
02-11-2015 10:58 PM
I tried both belkin options but got the yellow triangle! The 'do it yourself' got the ping working but no speed or noise.
02-11-2015 11:16 PM
I think it's time to call it a day with RSL and this Belkin. I think the best thing tomorrow (daylight) would be would be to gracefully 'Disconnect' as previously explained and put the TG582n back on. When you have it on, post that you have, and we can ask Plusnet to push a firmware update to it. The only criteria is that it must be on, don't switch it off whilst the update is occurring (you'll see all the lights go off and behave as though it's rebooting) and it'll be best if no-one is using the connection at the time.
RSL is easy to set up for the TG582n.
03-11-2015 10:15 AM
03-11-2015 10:35 AM
03-11-2015 10:59 AM
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1.472
Data Transferred (Sent/Received) [MB/MB]: 1,08 / 4,43
Output Power (Up/Down) [dBm]: 12,1 / 16,6
Line Attenuation (Up/Down) [dB]: 31,5 / 63,5
SN Margin (Up/Down) [dB]: 14,0 / 6,2
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 9 / -
Loss of Signal (Local/Remote): 1 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 76 / -
FEC Errors (Up/Down): 71 / 24.328
CRC Errors (Up/Down): 49 / 661
HEC Errors (Up/Down): -9 / 661 / 4.417
03-11-2015 11:04 AM
03-11-2015 11:08 AM
Well see if we can get the 10.2.2.B firmware pushed.
03-11-2015 11:27 AM
03-11-2015 11:36 AM
03-11-2015 1:38 PM
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1.408
Data Transferred (Sent/Received) [MB/MB]: 8,61 / 16,80
Output Power (Up/Down) [dBm]: 12,1 / 16,4
SN Margin (Up/Down) [dB]: 13,0 / 6,8
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Error Seconds (Local/Remote): 2 / -
FEC Errors (Up/Down): 135 / 25.922
CRC Errors (Up/Down): 19 / 6
HEC Errors (Up/Down): - / 25
btw speedtest says system busy
tbb speedtest error code 4136
connection keeps disappearing - have tried to post this three time now but page times out....
03-11-2015 2:19 PM
The time-outs here could be due to the forum, others are getting strange problems including myself.
03-11-2015 3:07 PM
Serial Number: CP1302
Software Release: 10.2.2.B
Software Variant: EH
Boot Loader Version: 1.0.5
Product Code: 3701603B
Board Name: DANT-T
>ping ntp.plus.net
Pinging ntp.plus.net [198.18.1.145] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 198.18.1.145:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
>ping ntp.plus.net
Request timed out.
Request timed out.
Request timed out.
Request timed out.
>ping ntp.plus.net
Request timed out.
Request timed out.
Request timed out.
Request timed out.
