Connected to gateway but not dns server
- Connected to gateway but not dns server
Re: Connected to gateway but not dns server
03-11-2015 9:45 PM
03-11-2015 9:53 PM
No I haven't, I think I have had enough today......Sorry.
03-11-2015 10:01 PM
03-11-2015 10:39 PM
04-11-2015 3:12 PM
04-11-2015 5:12 PM
Personally I've never found the cache to serve any useful purpose, I even turned mine off.
@mushroommrs
It seems highly probable that this problem is related (at least in part) to the Windows 10 DNS issue, but to eliminate other potential issues with the cause of extended latency, as previously mentioned you should be connected direct to the TG582n via Ethernet (and turn off the wireless).
The times on hop 1 of the tracerts seem fine since the firmware upgrade, so I'm not putting the TG582n at the top of the suspect list at this time.
Check telnet is still working, and if you haven't been running anything that would telnet the 582n for an hour or two, if there were already two active sessions, they should have died by themselves. But as previously explained you can check if RSL doesn't seem to get the data,and kill any active sessions.
04-11-2015 5:23 PM
I got rid of the Belkin bit showing in the IPCONFIG/ALL. ran all the ipconfig flush etc in elevated.
C:\WINDOWS\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : SJH-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 70-1A-04-3F-46-09
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-26-9E-57-57-73
Link-local IPv6 Address . . . . . : fe80::499d:ffa3:6add:ed76%18(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.72(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, November 4, 2015 3:49:50 PM
Lease Expires . . . . . . . . . . : Thursday, November 5, 2015 3:49:49 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 234890123
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-7B-E9-98-00-26-9E-57-57-73
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
Link-local IPv6 Address . . . . . : fe80::28b0:fa11:edf8:ab42%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.70(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, November 4, 2015 11:48:56 AM
Lease Expires . . . . . . . . . . : Thursday, November 5, 2015 3:49:53 PM
DHCPv6 IAID . . . . . . . . . . . : 369107551
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:24ef:1f2a:3f57:feb7(Preferred)
Link-local IPv6 Address . . . . . : fe80::24ef:1f2a:3f57:feb7%8(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 738197504
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Have redone the RSL again, Telnet says logged in. Still no noise or speed though. I have just reconnected to wireless.
04-11-2015 9:36 PM
Quote from: Anotherone There are no spoofed addresses in the ipconfig /all. The spoofed addresses all begin 198.18.1.xxx
Sorry- at least I covered myself saying I know not what I say.
It was reading this ( last few posts) where someone says they have fixed it. I see noe it was just the wifi that didnt work
http://www.techsupportforum.com/forums/f31/serious-internet-problem-1033761.html ; (more about win 10 upgrade)
They somehow changed the dns servers in the wireless lan section
The DNS servers in the ethernet part were working on 8.8.8.8.
And looking at mushroommrs ipconfig it has the DNS servers as : 192.168.1.254
which as you say are not spoofed but are possibly not DNS server either?
Wireless LAN adapter Wi-Fi 2:
Connection-specific DNS Suffix . : Belkin
Description . . . . . . . . . . . : TP-LINK Wireless USB Adapter
Physical Address. . . . . . . . . : C4-E9-84-0B-C4-33
Link-local IPv6 Address . . . . . : fe80::6027:11cf:dfca:96c5%23(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.34(Preferred)
Lease Obtained. . . . . . . . . . : 25 August 2015 22:02:50
Lease Expires . . . . . . . . . . : 02 October 2151 04:51:23
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DHCPv6 IAID . . . . . . . . . . . : 130345348
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-2C-80-3F-50-46-5D-2E-AC-65
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
04-11-2015 10:52 PM
With most routers you can change the DNS it uses, you can also specify the DNS you want to use on a Windows machine as well. (I assume you can also do it on other machines).
@mushroommrs
That's really odd about RSL .I'll have a read through my settings (which I've used before) - unless I made a mistake pasting it up for you. There's another RSL "expert" who I know has been watching the thread, I'm sure she'll chip in if she's spotted anything in case I've missed a tick here or there
If that sync speed holds, your Current Line speed will need to go up to match the IP Profile before you'll see the benefit.
The ipconfig /all looks OK as far as I can tell.
What have tracert's been like? Is the ping plotter still producing lots of off the scale values?
04-11-2015 11:22 PM
I'm wondering if the RSL isn't logging in to the router? Still can't access the technicolor via Firefox, only via Edge. Neither can I get the netgear extender to work indoors. It's ok in the office everything connects to it ok. As soon as I bring it in connection fails. Which is odd. Can't pick up the tech. From the sitting room either which I could, albeit a crap signal.
04-11-2015 11:34 PM
If you can post the full xDSL stats when you have time, the link in my sig should work just as well in Edge.
The wireless issue isn't anything as daft as just being on a different channel?
Could you have accidentally saved the wrong password in Firefox for the TG582n, I can't think of anything else at the moment.
Did you by any chance create a separate user for RSL to use? - I don't think I've talked about that, but that shouldn't stop it atm anyway.
05-11-2015 12:02 AM
No seperate user fo rsl (no clue)
05-11-2015 8:20 AM
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1.568
Data Transferred (Sent/Received) [MB/MB]: 149,86 / 183,32
Output Power (Up/Down) [dBm]: 12,3 / 16,8
Line Attenuation (Up/Down) [dB]: 31,5 / 63,5
SN Margin (Up/Down) [dB]: 14,0 / 7,4
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 106 / -
FEC Errors (Up/Down): 352 / 6.777.935
CRC Errors (Up/Down): 81 / 158
HEC Errors (Up/Down): - / 431
05-11-2015 8:55 AM
Does it plot as zero or is it just blank?
In RSF on each graph there is a tickbox at the bottom left corner and you can select
or de select if a graph is plotted. Are yours ticked?
Also on the configuration screen it lists 6 graphs with tick boxes to select which you want. Again are they all ticked
Also if you have been ticking and unticking already maybe close RS leave it a few minutes then restart.
Instruction from help page:
If you select or de-select a graph once RouterStats has started plotting, it's recommended that you close RouterStats completely and re-open it. This is especially recommended if all the graphs are configured to be dragged together.
05-11-2015 9:21 AM
It plots as zero
I have 3 of the 4 boxes ticked under Graphs - haven't ticked Plot average value of previous
Have close and reopened every time I have tried something. Or started from scratch...
