Connected, No internet - ADSL
gypsyreiver
Struggling to maintain a stable connection on devices. Showing Connected, No internet and then loses connection.
Tried disabling wifi and back on again, connection lasts a few seconds and then goes off again.
I see other threads on this but not sure what the issue is.
Router is showing green lights.
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
2 - Serial number: N7210741B004890
3 - Firmware version: 7.275.11_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 3 days 18:56:45
7 - Data rate: 819/14187
8 - Maximum data rate: 932/14676
9 - Noise margin: 14.2/3.8
10 - Line attenuation: 16.5/29.0
12 - Data sent/received: 1.8G/678.5M
20 - Broadband username:
21 - Wi-Fi network/SSID: Beechburn
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 300 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: 1
25 - Firewall: Default
26 - MAC Address: b0:bb:e5:e8:b5:23
27 - Software variant Version 1.0
28 - Boot loader: 7.275.11
10 REPLIES 10
Legend
Fixes: 254
Re: Connected, No internet - ADSL
Is this on mobile devices, or laptops/desktops?
gypsyreiver
On laptops, hard to notice on mobile since 4g connected to these also.
Legend
Fixes: 254
OK - next question. Over Wi-Fi, or ethernet connections?
Fixes: 418
@gypsyreiver
Is this just a continuation of this problem? If so you are just causing confusion by starting a new topic https://community.plus.net/t5/My-Router/iphone-11-unable-to-connect-to-wifi/m-p/1818716#M27262
Legend
Fixes: 254
@Baldrick1 Difficult to tell - previous topic didn't mention fixed devices.😉
gypsyreiver
Not sure i'm best qualified to answer that, that was specific to iphone unable to actually connect to the network full stop. This is a connection which is dropping out when connected, so i should think they are not related.
Do i just raise a fault and track it that way, if this is not the best mechanism to get solved.  If this is not the place to get help from plusnet i'll go elsewhere.
Regards
Legend
Fixes: 254
If you reply to my question in post #4, we may have a better idea of what to suggest.
Fixes: 418
@gypsyreiver
It's very simple really, are you able to get a stable connection on a computer connected to the Internet when it's connected via an Ethernet cable? If so then it's a wireless problem, the same as it was in your last topic.
Reading your last paragraph, if you do not want advice from fellow customers then do say so and I for one will go away.
gypsyreiver
WIFI. 3 metres from router so no issues with signal. I could plus an ethernet but kind of defeats the object and is not practical.
Is there an error log on the router, tried to find one but doesn't seem to exist like my old BT Hub.
Regards
Legend
Fixes: 254
Just try with a cable - that would confirm it is a Wi-Fi issue, and we may have further suggestions. We ARE trying to help here.
