Confused: why has my speed dropped on ADSL2+
- Confused: why has my speed dropped on ADSL2+
Re: Confused: why has my speed dropped on ADSL2+
23-05-2009 11:36 PM
24-05-2009 12:30 AM
24-05-2009 12:43 AM
http://www.dslreports.com/tweakr/block:14a0d7e?service=dsl&speed=4000&os=winXP&via=pppoA
24-05-2009 12:58 AM
David
24-05-2009 10:24 AM
up speed 929100.....down 39421000
SNR 10.0
atten 33.0
25-05-2009 12:12 AM
Since you mentioned receiving an email from Plusnet requesting you to carry out a tweak test I assume you have a speed fault ticket open. In which case I suggest adding the current results (comment, router stats image, and tweak test URL) to it and returning it to the CSC.
David
25-05-2009 11:46 AM
is it OK to go back and reset that ? as I dont want to do anything while you guys are handling things, I'm not the expert lol
http://www.dslreports.com/tweakr/block:585361e?service=dsl&speed=4000&os=winXP&via=normal
Barry
25-05-2009 12:07 PM
25-05-2009 12:37 PM
The latest tweak test shows slightly different Round Trip Time behaviour from previous ones, though otherwise it is much the same as before. (Whether you set mode to "normal" or "PPPoA" affects only the MTU recommendations, not the test results.)
David
26-05-2009 11:41 AM
Quote Dear Mr Shaw,
As per our discussion today.
I have spoke with BT and there is no banded profile on your line and essentially what you are receiving in terms of speeds on your line, is what your line can handle.
Please monitor your connection and should you have further problems, please let us know.
Kind regards,
Keith *******
Rgds Barry
Moderator's Note by David (spraxyt): Agent's full name removed as per Forum Rules.
26-05-2009 12:56 PM
What Keith is saying there is that your line speed isn't being capped by a "banded profile".
I'd like to see if your noise margin can drop a little more automatically. Has it always been at 10dB or have you noticed much in the way of fluctuations?
29-05-2009 2:21 AM
Uptime: 0 days, 0:16:57
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,042 / 3,898
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 26.5 / 46.5
SN Margin (Up/Down) [dB]: 6.5 / 9.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 6
CRC Errors (Up/Down): 4,294,967,264 / 0
HEC Errors (Up/Down): 0 / 0
Rgds Barry
12-06-2009 11:04 PM
http://www.draytek.co.uk/support/kb_vigor_mtu.html
Also on the maintenance menu it has he abiity to show a bits per bin graph which is often illuminating.
15-06-2009 1:33 PM
Rgds barry
15-06-2009 1:54 PM
the reading is now
Upload 833600
Down 4962800
SNR 6.5
Att 35.5
