Confused: why has my speed dropped on ADSL2+
Bojangles
Re: Confused: why has my speed dropped on ADSL2+
Quote from: Barxme
Morning all
I have been to start>>run...and typed in  " telnet 192.168.1.1"   the command window opens then disappears  not sure the reason for this.
or what to do next. ?
You need to run 'cmd' to get to the command prompt. Then you type 'telnet 192.168.1.1' . You'll get a prompt for the router login password.  'show adsl' will bring up some more stats.
Watching this thread as I'm thinking of having a go at tweaking my connection as its lower than predicted.
spraxyt
Resting Legend
Fixes: 75
The following guidance might also be useful.
To copy information displayed in the command window to the clipboard (for later pasting elsewhere) right-click in the window then
click Select All (to do what it says on the tin), or
click Mark, point to the left-hand margin of the line where copying is to start, press and hold the left mouse button while dragging the pointer to the right-hand margin of the last line to be copied. The area selected should display as black text on a white background.
Right-click in this area; the text will revert to white on black with the copied text on the clipboard.
Paste this into Notepad, or as required.
David
David
Barxme
Thanks bojangles, that worked ! however no luck in connecting to telnet
James
Try 192.168.1.1
169.168.1.1 isn't a valid address.
Barxme
ok guys got there, turned zone alarm off.
Think this looks OKEY DOKEY
Barxme
sorry about that first command promt, i sent the wrong one, when i did put the right ip in , the firewall blocked it but all ok now.
thanks again for all the help. I'm learning valuable lessons here, Oh!  i  knew how to cut and paste
, just didn't know how to put the stats in from router..lol
David when i changed the details in Dr TCP  the adapter settings said ........microsoft TV/Video connection....changed that to marvel yukon....and saved it...when i went back it changes back to microsoft TV/Video connection....all the time... is that correct ?
anyway gonna be patient and quiet now ...see how it all pans out...
thanks again Barry
spraxyt
Resting Legend
Fixes: 75
Quote from: Barxme
Yes, Dr TCP doesn't remember settings itself, it picks up values from the Windows registry. For the adapter setting it always shows the first one on the list and if a later one is in use that always has to be selected. The RWIN setting will be taken from that saved in the registry last time.
For setting your router MTU via the telnet interface the parameter name looks as though it is the Maximum Segment Size (which is 40 bytes smaller than the MTU). However online support information confirms that subtraction is done internally and the value to be specified is actually the MTU.
If you type wan ppp_mss ? (with the question mark) at the telnet prompt the current MTU value 1442 should be displayed. To reset it to 1500 you need to type wan ppp_mss 1500 to set the MTU to 1500. Then restart the router to make the new value take effect.
I would also restart the PC after the router reconnects, though strictly that might not be necessary.
For the record please attach the rectangular image of your router stats immediately after restart (I think running show adsl at the telnet prompt gives more complete information), then run a DSLReports Tweak Test after the settings have been changed and post the results URL.
David
David
Barxme
> show adsl
Version=                                        119
DspFirmwareVersion=                            E.38.2.23
DSPVersion=                                    0x00000050
Connected=                                      True
OperationalMode=                                G.Dmt.Bis
State=                                          Showtime
Watchdog=                                      0x00000053
OperationProgress=                              0x00000000
LastFailed=                                    0x00000063
TxBitRate=                                      883400
RxBitRate=                                      3748800
TxCellRate=                                    2083
RxCellRate=                                    8841
PhyTXCellCount=                                12862
PhyRXCellCount=                                47484
PhyCellDropCount=                              1
OverallFailure=                                0
LocalITUCountryCode=                            0x0000B5FF
LocalSEF=                                      0
LocalEndLOS=                                    0
LocalSNRMargin=                                12.0 dB
LocalLineAttn=                                  34.0 dB
LocalTxPower=                                  12.4 dB
LocalFastChannelRxRate=                        0
LocalFastChannelTxRate=                        0
LocalFastChannelFEC=                            0
LocalFastChannelCRC=                            0
LocalFastChannelHEC=                            0
LocalFastChannelNCD=                            0
LocalFastChannelOCD=                            0
LocalInterleavedChannelRxRate=                  0
LocalInterleavedChannelTxRate=                  0
LocalInterleavedChannelFEC=                    0
LocalInterleavedChannelCRC=                    0
LocalInterleavedChannelHEC=                    0
LocalInterleavedChannelNCD=                    0
LocalInterleavedChannelOCD=                    0
RemoteSEF=                                      0
RemoteLOS=                                      0
RemoteLineAttn=                                26.5 dB
RemoteSNRMargin=                                12 dB
RemoteFastChannelFEC=                          0
RemoteFastChannelCRC=                          0
RemoteFastChannelHEC=                          0
RemoteFastChannelNCD=                          0
RemoteInterleavedChannelFEC=                    0
RemoteInterleavedChannelCRC=                    0
RemoteInterleavedChannelHEC=                    0
RemoteInterleavedChannelNCD=                    0
LocalMgmtFEC0=                                  34
LocalMgmtCRC0=                                  0
LocalMgmtFECErroredSec=                        25
LocalMgmtErroredSec=                            0
LocalMgmtSeverelyErroredSec=                    0
LocalMgmtLOSErroredSec=                        0
LocalMgmtUnavailErroredSec=                    0
LocalMgmtHEC0=                                  0
RemoteMgmtFEC0=                                0
RemoteMgmtCRC0=                                0
RemoteMgmtFECErroredSec=                        0
RemoteMgmtErroredSec=                          0
RemoteMgmtSeverelyErroredSec=                  0
RemoteMgmtLOSErroredSec=                        0
RemoteMgmtUnavailErroredSec=                    0
RemoteMgmtHEC0=                                0
LocalTPSTCCell0=                                8767162
LocalTPSTCCell0UpperLayer=                      47480
LocalTPSTCBitError=                            0
RemoteTPSTCCell0=                              0
RemoteTPSTCCell0UpperLayer=                    0
RemoteTPSTCBitError=                            0
SRA=                                            Disable
PSDMask=                                        NonOvlp-M1
ActivateLine=                                  None
HostControl=                                    Enable
AutoStart=                                      True
Failsafe=                                      False
Action=                                        Startup
Standard=                                      G.Dmt.BisPlus Auto
UtopiaInterface=                                Level1
EcFdmMode=                                      EC
MaxBitsPerBin=                                  15
TxStartBin=                                    6
TxEndBin=                                      31
RxStartBin=                                    6
RxEndBin=                                      511
RxAutoBinAdjust=                                Disable
TxAttenuation=                                  -0.0 dB
BitSwap=                                        Enable
BitSwapUp=                                      Enable
NTRMode=                                        Disable
AnnexType=                                      G.Dmt.Bis
MaxDownRate=                                    511
PhysicalPort=                                  0
DetectNoise=                                    Disable
Capability=                                    ADSLPLUS, Value=0x10
CodingGain=                                    auto
FramerType=                                    Type3
DyingGasp=                                      Disable
Defaults=                                      None
FULL_RETRAIN=                                  Overall Retrain
Ok David all done and posted back Barry
Barxme
pretty naff upload now....... lmao
Barxme
Speed Tests
                                                    Down                                                    Up
Today 05:06                  2747 kbps (343kB/s)                          671 kbps      (83.9kB/s)
Yesterday 00:20          2712 kbps (339kB/s)                            14 kbps      (1.75kB/s)
Wednesday 09:47      2728 kbps (341kB/s)                          601 kbps      (75.1kB/s)
Tuesday 21:52            2748 kbps (344kB/s)                            15 kbps      (1.88kB/s)
Tuesday 21:50            2746 kbps (343kB/s)                            15 kbps      (1.88kB/s)
posting my latest speed tests  download has got better but upload is a yoyo
James
Hi Barry,
Have you tried installing and running Dr. TCP on your computer?
Try using an MTU of 1430 (and also on your router) and a receive window of 55600 and just see if it makes any difference.
You'll need to reboot the computer and the router after making the changes.
Barxme
Hi James, yes i have run Dr TCP as advised by spraxyt further up....and changed the MTU from 1442 to 1500, and the RWIN to 256960,
  Rgds Barry
Barxme
If the box on the right of the adapter name contains a value smaller than 1500 I suggest leaving the settings as they are for the moment.
That box was blank so I left it alone
James
Can you try 55600 for me please?
Barxme
James/David,  firstly sorry for delay, have just had back tooth out been suffering for days, also had computer issues.  no post showing or windows, just desktop after login..sorted that!
anyway. here goes DR TCP  changed the rwin to 55600...and entered 1442 in the MTU.....then command prompt  changed value to 1442....rebooted PC and router heres the tweek results..
http://www.dslreports.com/tweakr/block:314ba95?service=dsl&speed=4000&os=winXP&via=pppoA
Rgds Barry...
