Confused after switch from Value to Premium
- Confused after switch from Value to Premium
12-02-2010 12:22 AM
Evening all. This morning I was switched from Value to Premium and even though I'm on a nice long line (previously getting about 1.3Mbps on normal ADSL max) I was expecting at least a little bit of a boost after the move! Thing is I check my router (an unlocked 2Wire 2700HG) stats and get this:
Protocol: G.DMT Annex A
Downstream Rate: 1632 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 9.0 dB (Downstream) 16.0 dB (Upstream)
Current Attenuation: 63.0 dB (Downstream) 31.5 dB (Upstream)
Current Output Power: 16.6 dBm (Downstream) 11.9 dBm (Upstream)
DSLAM Vendor Information: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
PVC Info: 0/38
Now the bit I'm not sure of is the protocol reading G.DMT Annex A. From what I've read this is standard ADSL......so is my router messing about or have I missed something fairly major somewhere?!?!
Thoughts/comments/solutions(!)
Luke
PVC Info: 0/38
Luke
Message 1 of 5
(1,044 Views)
4 REPLIES 4
Re: Confused after switch from Value to Premium
12-02-2010 2:51 AM
I'm pretty sure G.DMT Annex A *is* ADSL.
My connection stats show some G.DMT framing and ADSL2 framing.
I'm on a plain ADSL Max solution, definitely not ADSL2, and I get:
[tt]
adslctl: ADSL driver and PHY status
Status: Showtime Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.3 22.0
Attn(dB): 30.0 19.0
Pwr(dBm): 19.8 11.9
Max(Kbps): 8960 1048
Rate (Kbps): 8128 448
G.dmt framing
K: 255(0) 15
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 1 1
B: 239 15
M: 1 8
T: 1 1
R: 16 16
S: 9.0000 9.0000
L: 1920 128
😧 16 2
Counters
SF: 3241165 3241163
SFErr: 283 8
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 183 2
OCD: 1 0
LCD: 0 0
[/tt]
Mike
[tt]
Mode: G.DMT
Channel: Fast
Trellis: ON
Down Up
SNR (dB): 9.3 22.0
Attn(dB): 30.0 19.0
Pwr(dBm): 19.8 11.9
G.dmt framing
K: 255(0) 15
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 1 1
B: 239 15
M: 1 8
T: 1 1
R: 16 16
S: 9.0000 9.0000
L: 1920 128
😧 16 2
Counters
SF: 3241165 3241163
SFErr: 283 8
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 183 2
OCD: 1 0
LCD: 0 0
[/tt]
Mike
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 2 of 5
(540 Views)
12-02-2010 8:08 AM
Welcome to the Forums lwhitworth
I think it takes more than a couple of hours to switch over, also not sure but dont think you will notice much change on that line
Message 3 of 5
(540 Views)
12-02-2010 10:52 AM
Hi Luke and welcome to the forums.
Your switch to ADSL2+ takes 5 days after your product is changed (so will be done by this time next week).
I'm not sure you'll see much improvement with those stats though.
Message 4 of 5
(540 Views)
12-02-2010 1:56 PM
Cheers for the reply folks, this is a very handy customer resource!
TBH I'm not expecting a huge increase, but as a certain supermarket says, every little helps
Message 5 of 5
(540 Views)
