Confirm Engineer Appointment
- Confirm Engineer Appointment
Re: Confirm Engineer Appointment
13-08-2014 4:06 PM
and the plusnet username is correct in the new router?
13-08-2014 4:10 PM
13-08-2014 4:13 PM
13-08-2014 4:14 PM
Can you run the following commands in your command prompt:
ping 8.8.8.8
and then
nslookup www.google.com
and
nslookup www.google.com 8.8.8.8
13-08-2014 4:36 PM
I using the username you use to log in to the plusnet website.
Also since I've been switched over every so often the internet light turns red and then goes back to green but I still can't access the internet.
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\Theo>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Theo>nslookup www.google.com
Server: dsldevice.lan
Address: fe80::9e97:26ff:fe36:f2e6
DNS request timed out.
timeout was 2 seconds.
*** Request to dsldevice.lan timed-out
C:\Users\Theo>nslookup www.google.com 8.8.8.8
Server: UnKnown
Address: 8.8.8.8
*** Request to UnKnown timed-out
C:\Users\Theo>
13-08-2014 4:44 PM
13-08-2014 4:46 PM
I can't really do much on a mobile phone
13-08-2014 4:47 PM
The tests I did earlier showed that the router is configured correctly with the username including the @plusdsl.net suffix.
I'd just go ahead and raise a fault as the next step, I don't think there's anything more you could check on your side.
13-08-2014 4:51 PM
I have an engineer coming tomorrow between 8am and 1pm, worst case scenario I'll just have to go back to adsl broadband if he can't fix it, but other than the engineer messing up at the cabinet/exchange I can't think of anything.
Was there any problems with my connection during the night? Is there any problems in the area that could be causing it?
Could it be a simple wait till midnight? or is that not the case here?
13-08-2014 5:16 PM
That's not right though, it should stay green ( or flash green ). Red indicates an authentication problem. Hopefully the engineer can sort it out tomorrow.
Quote Also since I've been switched over every so often the internet light turns red and then goes back to green
13-08-2014 5:19 PM
14-08-2014 9:36 AM
Turns out the contracter yesterday put me on the wrong port, so I know have fibre optic
Thanks for the help yesterday.
The BT engineer told me on his speed test he got 73Mb down and 18Mb up
Although wireless I get 40Mb but hey who cares I have fibre optic.
Is there anyway to reduce my ping? I have a ping of 25 and I have had lower when I was on adsl.
Thanks peeps
14-08-2014 9:40 AM
14-08-2014 9:42 AM
I'm using wired atm so I can enjoy the full potential of my connection
My only wireless device is my phone and soon to be tablet.
14-08-2014 9:53 AM
