Comments concerning enablement dates
- Comments concerning enablement dates
Re: Can't Volunteer (Exchange to be enabled on or after 01/04/2009)
18-12-2008 7:33 PM
Quote from: Santiago I think the internet will be worn out before my exchange is enabled
21CN PSTN switchover target: Q4 2010
was there no date for wbc santiago?. sounds like thats the date to switch the phone network over not enable for adsl2+
18-12-2008 8:00 PM
BT Wholesale information
ADSL status: Enabled as of 08/10/2003
ADSL Max status: Enabled as of 31/03/2006
SDSL status: Not available
21CN WBC status:Not available
18-12-2008 11:15 PM
18-12-2008 11:37 PM
Thanks for the link. From usertools I got this
Quote BT have advised that no current planned date for WBC on 21CN exists
Is that as bad as it can get?
19-12-2008 12:17 AM
Quote from: Santiago Is that as bad as it can get?
I assume the Samknows and UserTools information comes from the same public-domain source so both sites should report the same information, as they do, which is sadly no WBC roll-out date set for your exchange.
Does the Exchange History diary at the bottom of the Samknows Exchange Status page give any clue that a WBC enablement date was previously set but withdrawn (no longer reported) from mid-August 2008?
For my exchange the enablement date was originally 18/02/2009, withdrawn in mid-August, then set again to 31/03/2010 in mid-November 2008. PSTN switchover is targeted as Q1 2009.
19-12-2008 1:23 AM
Wholesale Broadband Connect is not yet available in your area
There is currently no 21CN migration date for your PSTN service
Looking at the exchange history I see:
19/10/2006 BT have set a target date of Q3 2009 for the switch to 21CN for the xxx exchange
19-12-2008 12:08 PM
Moderator's Note: Exchange checker says the Ripon exchange is esimated to go live on WBC on 31st March 2010. Hence moving this post to the correct thread. David (spraxyt)
19-12-2008 12:47 PM
Quote from: spraxyt Does the Exchange History diary at the bottom of the Samknows Exchange Status page give any clue that a WBC enablement date was previously set but withdrawn (no longer reported) from mid-August 2008?
There are only two comments in the History
29/10/2007 Carphone Warehouse (Talk Talk) has enabled the xxx exchange for their service
19/10/2006 BT have set a target date of Q4 2010 for the switch to 21CN for the xxx exchange
19-12-2008 10:55 PM
20-12-2008 12:00 AM
20-12-2008 12:02 AM
Might as well look on the bright side.
22-12-2008 5:56 PM
Quote from: spraxyt Maybe BT only withdrew the quarter-based enablement target dates when they knew they wouldn't be met. As experience is gathered the process could speed up so the later dates remain plausible.
We've got about 379 exchanges scheduled to be done between now and the end of March 2009 (169 done already or scheduled to be done by the end of last month). Then the forecasted dates go 6 monthly up to March 2011 (apart from September 2010). Hopefully there's plenty of room for some of the dates to be brought forward and for the remainding ~4000 exchanges to get dates. I can see things speeding up once the process gets moving, but we'll have to see I guess.
Plusnet Technology
29-12-2008 4:44 PM
Posts previously in this "Can't Volunteer" topic but mentioning 21CN Ready For Service dates up to 31/03/2009 have been moved to a new "Volunteers" topic here. I understand that Dave T will be requesting those affected by this to confirm they really do want to volunteer.
David (spraxyt)
04-01-2009 6:35 PM
Moderator's Nute: Although the main exchange WBC Ready For Service target date is 31/03/2009, as noted in the post no date has been set for this satellite exchange. Hence post moved to the "After 01/04/2009" thread. One assumes 21CN preparations are being made in this exchange since its target 21CN telephone service date is the same as that for the main exchange (Q2/2009). David (spraxyt)
07-01-2009 11:44 AM
Eventually all the exchanges should get done (there might be some of the really really tiny ones with less than 100 lines that don't but there aren't many of them). At the moment only about 1000 or so have had dates set (there are over 5000 exchanges altogether) over the next 2 years, we'd expect to see more dates come in as they start getting through these 1000.
Plusnet Technology
