'Clr rej. LTb still evident'
- Re: 'Clr rej. LTb still evident'
08-06-2010 3:01 AM
Can you tell me what ''Clr rej. LTb still evident'' means.
Message 1 of 4
(1,490 Views)
3 REPLIES 3
08-06-2010 7:52 AM
Where are you seeing this?
If it is in a ticket, what is it related too?
Message 2 of 4
(414 Views)
08-06-2010 8:06 AM
Hi Robin,
Clear reject means that we have passed the fault back to BT for further investigation.
LTB still evident means that the Lower Threshold Breach (your line is synchronising at a speed lower than your fault threshold rate) is still being seen by us.
It's an internal note in relation to your fault.
Message 3 of 4
(414 Views)
08-06-2010 9:22 AM
Hi Jameseh thanks for the info
Regards Robin
Regards Robin
Message 4 of 4
(414 Views)
