Closure of network port 500
- Re: Closure of network port 500
09-08-2012 3:11 PM
Hi can anyone tell me whether Plusnet has shut down network port 500? I use a works laptop from home occasionally which uses port 500 to establish a VPN connection. Its stopped working about 2-3 weeks ago and now I cant connect from home anymore onto my works system, I can still use VPN on a BT broadband business account hub so I know its not the laptop.
Never had a problem before now and have been made aware that other IPS are blocking this network port. Phoned Plusnet helpdesk and they could not help they suggested posting on here!
Thanks for your help.
Carol
Carol
Message 1 of 8
(1,519 Views)
7 REPLIES 7
09-08-2012 5:09 PM
Message 2 of 8
(847 Views)
10-08-2012 1:31 PM
Hi
I run by VPN client, it runs for about 10 sec before it stops with message. Terminated locally by client ,Remote pier no longer responding. I never get to the point of establishing a connection. As I said before I've had no problem up until a few weeks ago. I've had my laptop tested at work on the broadband line there (BT) and it connects without a problem. When I first came to plus net I couldn't connect and they altered somthing on my account and its worked ever since - until now.
Carol
Carol
Message 3 of 8
(847 Views)
10-08-2012 1:45 PM
Have you tried disabling the Plusnet firewall
Message 4 of 8
(847 Views)
10-08-2012 2:25 PM
Hi
I haven't tried that. can the firewall change its own settings? As I've had no problem before and I havent changed any of my settings.
How would I check my firewall settings?
Message 5 of 8
(847 Views)
10-08-2012 2:49 PM
https://portal.plus.net/my.html?action=firewall
Interesting - mine is shown as off but before I changed products I think it was on low so it appears that something changed it and I don't think it was me
Message 6 of 8
(847 Views)
10-08-2012 3:15 PM
Since 'Manage my useage' reverts to default on a product change I'd not be surprised if the firewall (and possibly other things) do too so don't forget to check your useage limit.
Call me 'w23'
Message 7 of 8
(847 Views)
10-08-2012 3:18 PM
The product you're on has the firewall set to 'low' by default and will have been like that for a while (it was introduced several years ago).
You can change the setting here: https://portal.plus.net/my.html?action=firewall&firewallPage=basic
Once you've done so, you'll need to disconnect/reconnect.
Message 8 of 8
(847 Views)
