Cisco Router compatible with ADSL2+ service
- Re: Cisco Router compatible with ADSL2+ service
05-11-2012 11:02 AM
Hi All,
I've been having problems with my cisco 877w since moving it away from an ADSL Max line, to an ADSL2+ line.
It seems from reading on various forums that there may be hardware and/or firmware issues with this router (eg. https://supportforums.cisco.com/docs/DOC-6183) and adsl2+ lines.
Just wondering if any of you have any other cisco recommendations, based on a working setup?
Thanks,
Leon
Thanks,
Leon
Message 1 of 7
(1,453 Views)
6 REPLIES 6
05-11-2012 11:06 AM
Hi Leon,
There are indeed some issues and it is recommended you are on the 0.0.26 DSL microcode, with a minimum IOS of 12.4(3)T (though 12.4(15)T is recommended).
The files needed are available for general download from Cisco. A full joint BT and Cisco briefing can be found on the following link.
http://www.cisco-bt-portal.com/iusr/DSL/Product_Bulletin_DSL.pdf
Message 2 of 7
(904 Views)
05-11-2012 11:35 AM
Hi Phil,
Thanks for the information.
Currently running IOS version 12.4(11)T with embedded adsl firmware.
Although you mention the adsl firmware should be available for general download, the cisco site will not let me download without a contract, which I don't have at the moment.
Leon
Leon
Message 3 of 7
(904 Views)
05-11-2012 11:39 AM
scratch that - a second link in the document does work.
I'll upgrade and see how it goes!!
Message 4 of 7
(904 Views)
06-11-2012 9:50 AM
An update for anyone else experience the same problem, uploading this ADSL firmware appears to have done the trick - with 20+ hours uptime now.
Leon
Leon
Message 5 of 7
(904 Views)
06-11-2012 10:02 AM
Good to hear.
This has undergone extensive use with our corporate customer base and we brief this on a regular basis to them. So I was aware this would likely help you.
One thing of note is that the router may still want to negotiate a faster speed than your line will allow. This doesn't always occur, but you will notice it if it occurs. If it does, ask us to change your stability profile from Standard to Stable or Super Stable.
This will take one working day and may then take a day or so to improve the situation. It may however cause a loss of anything form 0 to 1600kbps of your speed, depending on how it reads the errors on the line.
Message 6 of 7
(904 Views)
06-11-2012 1:47 PM
Hi Phil,
The current sync speed is....
Noise Margin: 8.5 dB 22.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 31.0 dB 15.0 dB
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 14336 0 446
Cells: 0 61476982 0 97333070
Reed-Solomon EC: 0 58770 0 0
CRC Errors: 0 1067 0 0
Header Errors: 0 895 0 0
I spoke to one of your guys on Saturday about the fact the upstream speed was previously close to 1Mb and he said it had been capped to 448, but would reset it which I think was due today. I'm guessing the modem will need to re-sync to pick up this change.
(I think this community account is linked to my home Plusnet line, rather than the business line to which I am referring, but I am listed as the primary contact in case you are trying to find me ;))
Leon
Leon
Message 7 of 7
(904 Views)
