Chnaged to unlimited and need some help
- Chnaged to unlimited and need some help
15-02-2013 8:12 PM
I have had unlimited for 14 days and it is running really poor, i have noticed that my game has started laggin (Guild wars 2) and streaming anything above 420p resolution lags and constantly is buffering. I am directly connected to the router with only myself connected but still i have these problems. I have noticed if i do a speedtest in a row they is a 7mb drop.
I have no idea what to do now.
http://www.speedtest.net/result/2511209299.png
Message 1 of 5
(1,522 Views)
4 REPLIES 4
Re: Chnaged to unlimited and need some help
15-02-2013 10:32 PM
What are your router stats when you look under "Broadband Connection"? http://dsldevice.lan/cgi/b/dsl/dt/?be=0&l0=2&l1=0
Message 2 of 5
(475 Views)
15-02-2013 11:19 PM
DSL Connection
Link Information
Uptime: 1 day, 6:57:06
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,196 / 15,208
Bandwidth (Up/Down) [kbps/kbps]: 1,192 / 14,254
Data Transferred (Sent/Received) [MB/GB]: 682.75 / 6.33
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 15.5 / 29.5
SN Margin (Up/Down) [dB]: 6.5 / 3.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 397 / 0
FEC Errors (Up/Down): 727,550 / 104,139,559
CRC Errors (Up/Down): 20,108 / 27,825
HEC Errors (Up/Down): 676,857,835 / 229,148
jim:green post tidied up mod:end
Link Information
Message 3 of 5
(475 Views)
16-02-2013 9:19 AM
Your problem is the appallingly high number of errors
One thing you could try as a short term fix is to resync the router in the late evening which should drop the speeds and hence reduce the errors
If you check the stats before and after you will probably find that the downstream noise margin increases fron 1dB to 3dB
A few questions - can you try the test socket and see if that fixes the problem. If it does your problem is likely to be your internal wiring
Message 4 of 5
(475 Views)
18-02-2013 10:38 AM
Message 5 of 5
(475 Views)
