Check my speed
Jarr
Check my speed
My broadband isn't up and running yet but where can I double check what speeds I can have?
4 REPLIES 4
Dhaos
Re: Check my speed
Re: Check my speed
SamKnows UK Broadband Availability Checker
Enter your phone number and postcode, and then on the following results page select each of the tabs going vertically down the middle of the screen to see what is available to you, and how fast it should be.
adamwalker
Fixes: 221
Re: Check my speed
An estimated speed should be visible to you after logging into the member centre on our website:
https://portal.plus.net/index_nlp.html
 Adam Walker
orbrey
Re: Check my speed
Alternatively you could try the BT checker at http://www.dslchecker.bt.com/adsl/adslchecker.welcome - that will tell you what services are available and give you an idea of the speeds you could expect for each one.
