Changing Upload speed, tried before
- Re: Changing Upload speed, tried before
08-04-2013 11:26 PM
ok so a while back i requested through the member center (help and support) to change it so i have a much better upload speed. After they changed my line it was much better (getting around 1.1mb) but my download suffered majorly (from 22mb down to just 8mb) i live about 100m away from the exchange so i dont see why this happened. Also i would love to just have fibire but it seems BT just missed my flat (above a take away) What else whould i try? another ISP? i have been debating for a long time about it...
Message 1 of 2
(574 Views)
1 REPLY 1
09-04-2013 9:11 AM
Quote What else whould i try? another ISP? i have been debating for a long time about it...
No where as we can't bring fibre to you any quicker (as much as we'd like to) let us help you out with the download speed issue.
You may be aware that uncapping the upstream of a connection can reduce the downstream slightly, but not to the degree you're seeing so without further ado I'd advise raising a fault: http://faults.plus.net (or call on 0800 432 0200 if you prefer).
I'm sure we can help you get that fixed and let me know if you need any further help or advice beyond that.
Adam
Message 2 of 2
(307 Views)
