Changing PC
- ADSL Broadband
- Changing PC
Changing PC
11-02-2008 7:49 PM
Im changing my PC and would like to know if I need my plusnet settings to change over. Im thinking of the modem and loggin in, as it usually does it automatically and I have no idea what my password would be!
Re: Changing PC
11-02-2008 7:58 PM
What ADSL equipment are you using? If its a USB you will need to install its software before you can use it. If you are using a router with Ethernet connection then you don't have to do anything regarding aDSL connection.
Re: Changing PC
11-02-2008 8:17 PM
Re: Changing PC
11-02-2008 8:22 PM
If you knew your password, it wouldn't tell you, but that'd be fine because you already know it.
Its when you don't know it that it would tell you, only you can't see it if you don't know your password.
Time to call PN Support methinks.
Re: Changing PC
11-02-2008 8:27 PM
Re: Changing PC
11-02-2008 8:29 PM
Re: Changing PC
11-02-2008 8:32 PM
Re: Changing PC
11-02-2008 10:25 PM
Re: Changing PC
11-02-2008 10:32 PM
Re: Changing PC
11-02-2008 10:48 PM
What kind of modem do you have? If your new PC is using Vista as opposed to Xp you should be aware that not all USB modems have Vista compatible drivers. It may be worth your while investing in a router. Routers don't need any drivers and tend to be better at maintaining a connection than USB modems.
What PN product are you on? If it's a legacy product and you change to BBYW you may be eligible for a free router.
