Changed to Premium Speed gone down to less than a 3rd of before :(
- Re: Changed to Premium Speed gone down to less tha...
03-11-2009 12:11 PM
Questions | ID: 30588774
Changed to Premium...thought I would get improved speed...was consistently getting 6500kbps now getting 1800 kbps...I am only half a mile from exchange in Birmingham
The speed drop started on the day of the changeover...cannot be coincidence..same thing happend when moved from Max to LLU and back again.
I restarted my router several times in the hope that it would connect at a better speed?...mistake...Plusnet thinks the restarts are disconnections!
I know there is nothing wrong with MY setup.
Fed up...just want things to work and an explaination not spend ages doing pointless tests over and over.
My router reports I am connected at over 8000kbps but all speed tests are around 1800kbps mark.
I now I am moaning...just frustration.
Message 1 of 5
(881 Views)
4 REPLIES 4
Re: Changed to Premium Speed gone down to less than a 3rd of before :(
03-11-2009 12:13 PM
Halfchan,
Could you post the results of a BT Speedtest (http://speedtest.bt.com) here so we can all see what's going on?
Message 2 of 5
(450 Views)
03-11-2009 12:36 PM
What does https://portal.plus.net/my.html?action=stable_rate say for your current line speed?
Message 3 of 5
(450 Views)
03-11-2009 12:49 PM
@halfchan, try disconnecting and reconnecting, you speed profile was set incorrectly at this side (sorry about that!)
Message 4 of 5
(450 Views)
03-11-2009 1:39 PM
Thanks Bob, that worked. Thanks guys for your other suggestions on finding a solution. B ack up to 6500kbps now...was hoping for better speed but I should count my blessings! lol
Message 5 of 5
(450 Views)
