Changed filter, IP profile increased, speed yet to?
- Changed filter, IP profile increased, speed yet to...
Re: Changed filter, IP profile increased, speed yet to?
04-01-2009 11:15 PM
Alan
05-01-2009 1:07 AM
Cheers for now,
Chris.
05-01-2009 10:53 PM
06-01-2009 10:48 AM
I used to sync at 8128 and it's gradually decresed to between 3500 and 4600. here's hoping the forced BT SNR change can do us all good.
Podman
06-01-2009 11:00 AM
Certainly once mine was unlocked from 15dB to 9dB it dropped automatically to 6dB a few days later.
06-01-2009 11:03 AM
06-01-2009 5:36 PM
14-01-2009 8:34 PM
Statistics Downstream Upstream
Line Rate 6208 Kbps 448 Kbps
Attainable Line Rate 6752 Kbps 1128 Kbps
Noise Margin 11.9 dB 22.0 dB
Line Attenuation 26.0 dB 21.0 dB
Output Power 12.4 dBm 19.8 dBm
IP profile increased to 5mb today, it seems the automatic system is working in my case, but it is a slow business. I will post back on what speed is finally achieved, seems as though it may take another week or two
14-01-2009 10:38 PM
DSL Status: Up
DSL Modulation Mode: GDMT
DSL Path Mode: FAST
Downstream Rate: 5664 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 7 db
Upstream Margin: 24 db
Downstream Line Attenuation: 42
Upstream Line Attenuation: 23
Last week I sync'd at 6272 with interleaving on so how knows what my sync may achieve. I'd previously been lucky to sync above 3500
podman
17-01-2009 8:25 PM
Looking good Alan, with a bit of luck you'll see SNRM target go to 9dB 7-11 days after the drop to 12dB, so maybe anytime in the next few days.
Podman, you maybe limited by your line noise & hence errors. Interleaving/Fast won't affect sync speed as such, but the resulting error rate may. It would be better to continue this in your own thread.
26-01-2009 7:00 PM
Line Mode G.dmt Line State Show Time
Latency Type Interleave Line Up Time Duration 14:03:38:11
Line Coding Trellis On Line Up Count 1
Noise Margin 12.1 dB 22.0 dB
26-01-2009 11:34 PM
You may need to resync to see if it's gone down. I'd wait until the margin is steadily at least 13 db or higher (in daylight - remember) before trying that. Best of luck.
Chris.
27-01-2009 10:59 PM
Alan
28-01-2009 8:53 PM
Line Rate 6400 Kbps 448 Kbps
Attainable Line Rate 6944 Kbps 1128 Kbps
Noise Margin 11.7 dB 22.0 dB
It seems my synch has increased just enough to move my IP profile up to 5500 although still waiting for this to be confirmed. Noise margin as I write is 10.5db.not sure if my NM is now 9 or still 12, I seem to remember reading somewhere that it increases or decreases in 3db increments?
28-01-2009 9:33 PM
But that's such a slow change.........
More patience is required; maybe by Easter you'll be back to normal
