Changed email re-direct still not working after 3 hours
- Re: Changed email re-direct still not working afte...
06-04-2009 4:11 PM
Good afternoon
I changed an existing re-direct from a username@virgin.net to a username@tiscali.co.uk account about 3 hours ago but it is still going to the old address.
Are there any problems on Plusnet causing this delay please?
Message 1 of 5
(974 Views)
4 REPLIES 4
Re: Changed email re-direct still not working after 3 hours
07-04-2009 9:07 AM
Is it working now?
Message 2 of 5
(507 Views)
07-04-2009 9:42 AM
Good morning and thanks for the response
No I have just tried it again and it is still going to the old e-mail address after 18 hours!!
I am going to delete the re-direct and configure a new one which should take PN half an hour to update their system.
I will update this post in a couple of hours
Message 3 of 5
(507 Views)
07-04-2009 10:41 AM
Hi John,
That's a sensible suggestion and it should work. Let me know if you continue to have problems setting up your redirect and I'll take a look myself.
Message 4 of 5
(507 Views)
07-04-2009 11:26 AM
Good morning again
The solution worked - deleting the re-direct and setting up a new one.
If I need to change one in the future I will probably use the delete/create new rather than trying to modify an existing.
Thanks again for the responses
Message 5 of 5
(507 Views)
