Change upload speed
- Re: Change upload speed
Change upload speed
20-11-2013 8:56 PM
Hi all,
I am new in this community.
I checked my upload speed using speedtest.net and it asserts my upload speed is 0.33Mbps. Sometimes I host lan parties with friends in remote (always around 4-5 people) and the best speed would be around 1Mbps.
Is there any way to change the upload speed (also partially reducing the download speed that is now ~7Mbps)? Which would be the cost of the operation in term of monthly payments?
Message 1 of 7
(916 Views)
6 REPLIES 6
20-11-2013 9:13 PM
The Digital Care Team who respond to forum posts work 9am to 5:30pm am sure someone in the morning with take a look at sorting your upload out
Message 2 of 7
(581 Views)
20-11-2013 9:21 PM
Simple question
Are you on ADSL2+ 21CN or ADSL 20CN
If you check your exchange here http://usertools.plus.net/exchanges/ ; and it says "BT have advised that this exchange is enabled for WBC on 21CN" then you can get the upload uncapped with no charge to give an upload speed of about 1,000kbps in your case
If it isn't then the only option is Max Premium http://www.plus.net/support/broadband/products/prioritised-service-faq.shtml which will give upload sync speeds of about 832kbps
Message 3 of 7
(581 Views)
20-11-2013 9:31 PM
Good! I can confirm that it says: "BT have advised that this exchange is enabled for WBC on 21CN"
Message 4 of 7
(581 Views)
20-11-2013 9:36 PM
In which case the change will be simple and quick - should be picked up tomorrow here
Message 5 of 7
(581 Views)
21-11-2013 12:52 PM
@electrictwister
I've placed a uncap order for you, this will complete tomorrow.
Message 6 of 7
(581 Views)
21-11-2013 7:32 PM
Thank you
Message 7 of 7
(581 Views)
