Cant connect to that network?
lcm
Devices throughout the house connected happily to PN for some time. Recently tried to connect two devices and both of them return error message' 'Cant connect to that network'.
One device is a laptop and it works fine on ethernet cable, but when I unplug it I cant connect to PN, after entering the password.
Existing devices still seem fine.
Any ideas?
7 REPLIES 7
Legend
Fixes: 254
Re: Cant connect to that network?
Which password are you using? It should be the Password (Key) on the sticker on the bottom/back of the router.
198kHz
Fixes: 41
...unless it's been changed from the default at some time.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Legend
Fixes: 254
@198kHz In which case, the OP should have a record of the 'new' key.
198kHz
Fixes: 41
Agreed.  🙂
lcm
Hi
Same password - nothing has changed on the router.
Legend
Fixes: 254
I know this is a silly question, but are you sure you're trying to connect to your network? That seems a strange message.
Marksfish
Seasoned Pro
Fixes: 4
How long has the router been on? Sometimes a reboot will allow new connections.
