Cant connect to my work VPN, help anyone??
- Cant connect to my work VPN, help anyone??
30-09-2011 6:29 PM
hi, i have xp home pc connected to netgear dgnd3300v2 and a dell laptop running windows 7 ultimate. i need to connect my laptop to my head office vpn to retrieve emails from ms exchange server. if i use my o2 dongle or my wireless heighbours bt home hub i connect to the vpn immediately but if i connect via my netgear via plusnet i get the message -the L2TP connection attempt failed becasue the security layer encountered a processing error during intial negotiations with the remote computer (error 789) .
can anyone help as i'm going nuts
Message 1 of 6
(16,806 Views)
5 REPLIES 5
Re: Cant connect to my work VPN, help anyone??
30-09-2011 8:31 PM
I used Outlook Web Access.
Message 2 of 6
(652 Views)
01-10-2011 12:31 AM
Have you activated the PlusNet firewall: https://portal.plus.net/my.html?action=firewall, any setting higher then 'low' may block VPN connections.
Call me 'w23'
Message 3 of 6
(652 Views)
01-10-2011 8:02 AM
Quote from: Strat I used Outlook Web Access.
thanks strat, i dont think i would be allowed, i think we have to use what thecompany provides or we get shot or something, even if it doesnt work.....
Message 4 of 6
(652 Views)
01-10-2011 8:24 AM
Quote from: walker23 Have you activated the PlusNet firewall: https://portal.plus.net/my.html?action=firewall, any setting higher then 'low' may block VPN connections.
hi walker23, in a word, you are a star, i set the firewall to low, rebooted the router and i connected immdeiately, you wouldnt believe how much time i have spent trying to resolve this, including an hour and a half on the phone to our IT 'experts' in germany
thanks very much
Message 5 of 6
(652 Views)
02-10-2011 11:01 AM
just got an anwswer to my ticket i raised before posting, they suggested it was my router and couldnt help............the forums win again!!!
Message 6 of 6
(652 Views)
