Cant access a website that I use regularly
- Cant access a website that I use regularly
Re: Cant access a website that I use regularly
16-02-2018 10:53 AM
@MauriceC wrote:
@Baldrick1 wrote:
Either there needs to be one international database, which is unlikely to happen, or for there to be a migration to IPv6, this will take years. So any ISP that is expanding and having to get unused IPv4 addresses from overseas are going to have these problems, as are organisations that can't accept IPv6 connections.
Roll on IPv6!
Sadly IPv6 aint the cure either.
Thanks for correcting me. In my innocence I assumed that there would be one authority who would allocate blocks of IPv6 addresses to nations. As there should be more than enough for every-one for the foreseeable future there would be no need for them to be traded between countries as stocks run low. Therefore the problem would disappear.
Obviously life cannot be this simple.
16-02-2018 11:37 AM
IT? Simple? Never, ever, ever in a million years, not while there are 'entities' that want control and people that just will not play nicely. When I first got into this in the early days (punch cards etc.) things seemed complex, but as things have moved on and more is required of IT, things have become much more complicated. It doesn't need to be this complicated but where there are vast amounts money to be made, especially for IT security and for the advertisers, things will alway be complicated or am I just a tuning into a cynical old git? Meh, perhaps I'm just past my 'best before' date
16-02-2018 11:49 AM
@gregshaw Are you still affected?
Ex-Broadband Service Manager
16-02-2018 4:35 PM
@Kelly YES - I can NOT access systmonline.
16-02-2018 4:51 PM
I was using the SO prescription service perfectly fine until my last holiday (September 2017) when my router was switched off for 16 days. Upon my return and powering up my router, everything was OK except for SO was not responding/timed out.
I presume now, that I had been allocated a new IP address.
We all now know the cause of this to be incorrect geo-location information between PN & SO.
As of this moment in time, absolutely nothing has changed in this respect, I can not access SO.
PlusNet and systmonline are both providing me with a service, for which I pay, however between them I am receiving no service at all in this case.
16-02-2018 5:26 PM
I suggest you contact your surgery and tell them about your difficulties and that you have been told it is because SystmOnline are using an incorrect/out of date lookup to determine if people are in the UK - ask the surgery to raise it with SystmOnline.
If SO get enough complaints they may eventually do something about it!
16-02-2018 6:05 PM
FIXED !! Thanks @Kelly for sorting this out.
I rebooted my router as per PM from Kelly. Came back on with a completely different IP (80........)
Everything working super fast, systmonline BBC weather/sport/news etc.
All sites with an "interest" in my location (i.e UK) now working instantly, no faff, no delay.
The Forums work!
Also, got to say, PlusNet have actually resolved my issue - THANKYOU.
16-02-2018 6:07 PM
Are you now on a fixed IP?
16-02-2018 6:28 PM
@jelv I don't know.
I have not asked for a Fixed IP.
Previously, rebooting my router did not change my IP.
My IP has now changed from 146.... to 80..... and works brilliantly at the moment.
Kelly said that I will "keep the new IP until the issue with SO is resolved".........?
I have asked Kelly what will happen if I reboot my router in the future.
16-02-2018 6:37 PM
By all means try, but they may need some 'persuading', especially if you are the only patient of theirs with the problem.
Really you need to find the relevant NHS body which commissioned the use of SO at your surgery - probably the local Clinical Commission Group for your area - and lobby them. They are the 'client' of SO, not you, so should have more weight. Point out also that SO's 'validation' of IP addresses is rather pointless anyway if it can be circumvented simply by using anonymous proxy servers.
16-02-2018 7:26 PM
@gregshaw wrote:
@jelv I don't know.
Have a look in https://www.plus.net/my.html?action=myconnection
16-02-2018 7:49 PM
@jelv wrote:
@gregshaw wrote:
@jelv I don't know.
@jelv - I have checked in my "member centre" from your link and YES, it's there "Fixed IP"
So PN have indeed transferred me to a fixed IP, which does not have any geo-location problems.
16-02-2018 7:57 PM
I have got to say that the staff at my local surgery had absolutely zero interest in my problem and that they "have nothing to do with systmonline" and to contact them direct (SO). As repeat prescriptions from SO were reaching the surgery (apparently normally) the problem was obviously mine and SO was working as it should!
17-02-2018 9:24 AM
Hi, I have this issue too - unable to access SO.SI havh rebooted my router but no change in ip. Please can you apply the fix to my connection? Thanks
17-02-2018 9:48 AM
