Cannot get Routerstats to work.Please help
jjaycee1
After playing a game yesterday I had a BSOD, and ever since then I just cannot get Routerstats to show me any info regarding Noise margin or Sync speed. I have set it up exactly as I had before, based on "Anotherone" guidance in my older post of "Am I going to be unhappy". It has worked fine but now I get my Noise Margin graph drawing a straight line on 0 and similarly on Sync speed. Can anyone help please. I am using Routerstat version 67g. I tried the newest version and the Lite but I get the same results.
37 REPLIES 37
jjaycee1
Re: Cannot get Routerstats to work.Please help
Here are my configuration settings. Pics 10 & 11 are what is showing when the programme is "running".
jjaycee1
Oldjim
Resting Legend
Fixes: 63
Does the routerstats log also show zeros
Which operating system are you using
jjaycee1
I cannot see a LOg file but I can see a "Routerstats2013-06-15.txt" file which only shows the following:
Sat 15 Jun 2013  11:15:04,
Sat 15 Jun 2013  11:15:15,
Sat 15 Jun 2013  11:15:24,
Sat 15 Jun 2013  11:15:35,
Sat 15 Jun 2013  11:15:44,
Sat 15 Jun 2013  11:15:55,
Sat 15 Jun 2013  11:16:04,
Sat 15 Jun 2013  11:16:15,
Sat 15 Jun 2013  11:16:24,
Sat 15 Jun 2013  11:16:35,
Sat 15 Jun 2013  11:16:44,
Sat 15 Jun 2013  11:16:55,
Sat 15 Jun 2013  11:17:04,
Sat 15 Jun 2013  11:17:15,
Sat 15 Jun 2013  11:17:24,
Sat 15 Jun 2013  11:17:35,
Sat 15 Jun 2013  11:17:44,
Sat 15 Jun 2013  11:17:55,
Sat 15 Jun 2013  11:18:04,
Sat 15 Jun 2013  11:18:15,
Sat 15 Jun 2013  11:18:24,
Sat 15 Jun 2013  11:18:35,
I am using Windows 7. I just reinstalled it and the files are in User/jon/AppData/local/temp/rar$EX00.856. Previosly installed in a desktop folder called Routerstats as it was when it was working fine.
Oldjim
Resting Legend
Fixes: 63
I suggest trying enabling telnet in Windows 7 as it may have been un-enabled (is that a word  ;D)
http://social.technet.microsoft.com/wiki/contents/articles/910.how-to-enable-telnet-client-in-window...
That is the log file which you can get to by clicking on the log icon
However the reason it isn't working is that it won't run may be the file location.
Extract all the files from the download to a folder on the desktop and try again
tijara33
Fixes: 6
I've no idea about Routerstats Jim, but I am an English Lang. major. May I respectfully suggest that "disabled" would be more appropriate?  Roll_eyes
Oldjim
Resting Legend
Fixes: 63
A good question.
However as it isn't enabled by default then returning to the default state isn't strictly speaking disabling it as it just means that it hasn't been enabled  Roll_eyes
tijara33
Fixes: 6
Mere semantics.  Shocked
Oldjim
Resting Legend
Fixes: 63
Of course but that doesn't invalidate the reason.
Of course not being an English Lang Major but only an aged Graduate (and Chartered until I stopped paying my subs) Engineer with 'O' Level English Language what would I know
Perhaps the word should be "deactivate", as that implies that the feature is merely switch off.
In my mind to "disable" suggests permanent impairment.
Fixes: 160
Back on topic...
Quote from: jjaycee1
That is windows system area - I'd not run it from there.  Re-extract the RouterStats files to somewhere like C:/routerstats and run the program from there.
Anotherone
Champion
Fixes: 21
Hello Jon. Were you using Windows 7 before, I can't remember?
But if you've re-installed it and there will also have been several security updates this may be the problem as some of the updates involved privileges issues, this is why townman suggested you re-install to to C:\RouterStats where that shouldn't be a problem. Also as mentioned by Jim, ensure Telnet is active. When you then run it, run as administrator if prompted.
I'd also update to the latest RS version 6.8h. In addition to the other settings, on the Bitloading>Options tab, I'd check the boxes 'Wait for username and password requests from router during login" also "Restore default router timeout when RouterStats is closed" with the values 2500msec for "Telnet Timeout" and 1 minute for "Router timeout" ... see attachment.
jjaycee1
Hi Anotherone: Have always used Win7. Have done exactly as you suggested, reinstalled in C and using version h. Have activated Telnet Client (not Telnet Server?) and confirmed it is operating correctly via the link Oldjim gave. Have included the Bitload "options" you gave regarding telnet.
Unfortunately I get the same result. A couple of points for your advice please. When I installed version "g" which was in place when I wrote my initial help request, I was getting my router details available in the Router Stats Page of the programme, which never was available before. It was always state unavailable but gave the option to click on the router web page and log in etc. Most unusual. I am also getting the info available from Router Stats page option in version h. The second main observation is that in both g & h versions I get a great deal of delay and "sticking" when the programme is running. If I want to slide the open, running programme to the left or right of my screen it sticks for ages before moving. It also has quite a few "not responding" notifications if i e.g try to change a config setting. This implies something is not right at all , as it never did that before. Any ideas? P.S I do not have the windows setting operating that requires Administrator ( is it UAC or something where it keeps asking you to verify etc)
Anotherone
Champion
Fixes: 21
This probably has more to do with the peculiarities of the TG582n as much as anything to do with RouterStats. Personally I won't drag the graphs around, it seems to cause more problems than it's worth. I just go and look at the Captured graphs. The only time I'd consider dragging is if I particularly wanted to do a Capture Now, showing several "features" that would otherwise be on different automatic captures.
Not sure about the sticking, I'll have a play in a short while. The "Wait for username ...etc" & timeout change to 2500ms may help with the not responding issue.
Are you also logged in to the modem/router GUI via your browser at the same time when all this is happening?
Has your TG582n got a USB port on it? And which version of Firmware is on it (don't post the serial number if you do a grab) a copy and paste of the data is easier to edit?
