Cannot connect to the router
- Re: Cannot connect to the router
22-04-2009 10:43 PM
I have just installed a WinXP Pro on another hard drive on the same computer, so I now have 2 identical operating systems on the same machine and I can select which to use at log on. The problem is that I cannot connect to the router from the newly installed WinSP, yet I am connected on the earlier installation.
The router is D-Link DSL 2640B. When I type http://192.168.1.1/ into Internet Explorer the router's logon screen does not appear and all I get is the usual "Page Unavailable" error message.
I have not tried re-setting the router for fear that I might then lose the connection that works.
Any help would be most appreciated as I don't know what to do next.
Many thanks,
Alex
Many thanks,
Alex
Message 1 of 4
(900 Views)
3 REPLIES 3
22-04-2009 10:47 PM
Might be very silly suggestion but when you installed the new XP version did you also install the network drivers for your motherboard as the new installation can't use the ones for the other installation
Message 2 of 4
(436 Views)
22-04-2009 10:54 PM
Quote from: hamilton36 I don't know what to do next.
The first thing I'd do is look in the Device Manager to see if anything useful is visible in the Network Adapters section and working.
Message 3 of 4
(436 Views)
22-04-2009 11:55 PM
Thank you Oldjim and HPsauce. You were right. It was the dreaded NVidia drivers and the NVidia Connection Manager. As I installed both form the CD a message flashed: "you have just connected to internet" and that was it.
Thank you again.
Alex
Thank you again.
Alex
Message 4 of 4
(436 Views)
