Cannot access some sites and ages on some sites
- Cannot access some sites and ages on some sites
27-11-2010 9:57 PM
Any idea why this might happens.
Re: Cannot access some sites and ages on some sites
27-11-2010 9:58 PM
28-11-2010 8:44 AM
www.gmx.com
http://www.espncricinfo.com/
www.speedtest.net
some pages under www.iii.co.uk
28-11-2010 9:03 AM
28-11-2010 9:54 AM
Try using Google DNS IP addresses 8.8.8.8 and 8.8.4.4
28-11-2010 4:24 PM
DHCP is enabled, all DNS service IP addresses are set at 0.0.0.0.
The problem sites are never completly downloaded with all the components needed. I tried 3 different machines and 3 different browsers; same issues on all with with slightly different results. For example, MS IE and Safari will not load www.GMX.com but Chrome is OK. Safari fails to www.apple.com. All fiails on https sites with logins and follow on secure pages.
IfI leave www.gmx.com in MS IE to load it does it in ~45 minutes. It seems this a speed problem but speed tests register 320 kbps speed.
28-11-2010 4:37 PM
212.159.13.50
212.159.6.9
212.159.6.10
28-11-2010 5:01 PM
What are the 'WINS' and 'Static Routing' settinga for Plusnet, if they help or are needed? They are all set to 0.0.0.0 at present.
Zoppz
28-11-2010 6:02 PM
28-11-2010 7:27 PM
See attached, made these changes and hardbooted the router. No improvement.
Zoppz
28-11-2010 7:51 PM
28-11-2010 8:28 PM
DNS Servers: 212.159.13.49/50/9/10 and 192.168.1.1.
Also, at the top DNS Suffix Serach List: 'domain_not_set.invalid'
28-11-2010 8:43 PM
This is what mine shows
Quote Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-1A-4D-59-68-29
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::3075:bb5f:9d3d:1bc4%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 22 November 2010 17:59:04
Lease Expires . . . . . . . . . . : 01 December 2010 09:29:29
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 234887757
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-72-15-1D-00-1A-4D-59-68-29
DNS Servers . . . . . . . . . . . : 8.8.8.8
212.159.13.50
28-11-2010 8:47 PM
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-23-54-C6-CE-81
Link-local IPv6 Address . . . . . : fe80::4575:8ffe:77cc:b12f%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.20(Preferred)
Lease Obtained. . . . . . . . . . : 28 November 2010 19:37:07
Lease Expires . . . . . . . . . . : 01 December 2010 19:37:06
DHCPv6 IAID . . . . . . . . . . . : 234890068
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-00-0C-44-00-23-54-C6-CE-81
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
29-11-2010 8:00 PM
I set the network adapter DNS setting to 8.8.8.8 and 8.8.4.4 as suggest by Oldjim last night. The ipconfig /all output shows it being set as that. Tired the www.gmx.com, which stop at 'secureaddthis.com' and www.MSDN.com sites, same result; still loading after 20 mins. The line speed as same as yesterday, ~3.2mbps.
Large simple site like BBC and Sky load slowly but are done in 20-30secs. Can't watch youtube in higeher resolution takes forever.
Zoppz
