Canarycity Speed fault
canarycity
Over last few days my speeds have dropped and I am on a fixed speed connection router stats:-
Uptime: 0 days, 0:12:20
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 724 / 2,544
Bandwidth (Up/Down) [kbps/kbps]: 728 / 2,552
Data Transferred (Sent/Received) [kB/kB]: 264.00 / 554.00
Output Power (Up/Down) [dBm]: 12.5 / 16.5
Line Attenuation (Up/Down) [dB]: 36.0 / 62.5
SN Margin (Up/Down) [dB]: 6.0 / 3.5
Loss of Signal (Local/Remote): 5,636,012 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 6,330,443 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 39 / 33
HEC Errors (Up/Down): 9 / 32
Also I am now getting disconnection and connections.
I am not new to broadband and have not had these problems since I was put on a fixed speed a number of years ago. And yes before anyone says I am on a long connection.
jim:green title changed after split off mod:end
2 REPLIES 2
canarycity
Re: Speed faults - information needed to help diagnosis
Just to add just done another speed test and its the highest download speed ever, so I have now today had dial up speed to 3.4mbps so it looks like my fixed speed has been taken off.
Oldjim
Resting Legend
Fixes: 63
Re: Canarycity Speed fault
Topic split off to it's own thread
