Can't log onto Metronet portal
- Can't log onto Metronet portal
03-09-2007 3:21 PM
Re: Can't log onto Metronet portal
03-09-2007 3:24 PM
I've tested this from here as advised on your previous thread, have you tried using a different browser? Are you getting the password reminder for the main account or for your connection account?
03-09-2007 3:34 PM
03-09-2007 3:35 PM
03-09-2007 3:37 PM
03-09-2007 3:40 PM
03-09-2007 3:53 PM
03-09-2007 4:48 PM
Problem is it sometimes submits your previously-saved password even if you change it. To cure this, to go Tools > Options... > Security tab > Passwords section > Exceptions... > highlight the site(s) you want to remove the password(s) for, then click Remove.
That should do it.
03-09-2007 4:50 PM
03-09-2007 5:01 PM
