Can't log in to Plusnet on newly installed TG582n Plusnet router
- Re: Can't log in to Plusnet on newly installed TG5...
25-09-2015 2:38 PM
Re: Can't log in to Plusnet on newly installed TG582n Plusnet router
25-09-2015 2:55 PM
25-09-2015 3:17 PM
25-09-2015 3:30 PM
This assumes that you are trying to get the router to connect to the internet and not to login to the member centre once you are connected
25-09-2015 4:50 PM
25-09-2015 5:04 PM
This may need staff assistance
25-09-2015 5:11 PM
Are you having problems getting the router to connect to the internet or are you having problems logging into your account on the Plusnet website?
25-09-2015 5:18 PM
25-09-2015 5:33 PM
25-09-2015 7:51 PM
25-09-2015 8:19 PM
Can you attach a screengrab of your open browser window, including the address bar, showing the Broadband Setup screen?
25-09-2015 9:05 PM
25-09-2015 9:13 PM
25-09-2015 9:15 PM
If that doesn't work you'll need to contact support and give them the serial number of the router so it can be removed from the original account and associated with yours. Failing that, buy another generic ADSL router.
25-09-2015 9:26 PM
