Can't get BBC radio live iPlayer live feeds locally via PlusNet
- Re: Can't get BBC radio live iPlayer live feeds lo...
23-03-2009 12:14 PM
I can't seem to get the iPlayer live BBC radio streams when connected to the net via PlusNet, although I can if connected via Nildram or NewNet.
The BBC radio iPlayer feeds in question are the high quaility asx ones and are restricted to UK users only. My current best guess is that the BBC seem to think that PlusNet are not based in the UK, as the stream appears to connect but is then refused.
Can anyone else on PlusNet receive any of these feeds via their local browser?
http://www.bbc.co.uk/radio4/wm_asx/aod/radio4.asx
http://www.bbc.co.uk/radio3/wm_asx/aod/radio3.asx
http://www.bbc.co.uk/radio2/wm_asx/aod/radio2.asx
http://www.bbc.co.uk/radio1/wm_asx/aod/radio1.asx
Thanks.
MC
Re: Can't get BBC radio live iPlayer live feeds locally via PlusNet
23-03-2009 12:17 PM
23-03-2009 12:19 PM
23-03-2009 12:55 PM
Edit now 4 also works but not 1 or 2
23-03-2009 1:24 PM
23-03-2009 1:25 PM
23-03-2009 1:32 PM
23-03-2009 1:39 PM
All still working.
23-03-2009 2:29 PM
23-03-2009 2:35 PM
Jim
23-03-2009 3:41 PM
23-03-2009 4:06 PM
23-03-2009 5:02 PM
I have fired up my laptop and guess what... the BBC playlists work.... however, on my main machine the BBC ones above still do not work...... but other ASX playlists do.
Makes no sense to me at all.
MC
23-03-2009 5:26 PM
Edit - one major difference Media Player 10 on XP 11 on Vista
23-03-2009 5:58 PM
only diff there could be is i didnt install the windows update in the capture and your running 64 bit vista
