Can't connect
- Can't connect
- « Previous
- 1
- 2
- Next »
Re: Can't connect
18-05-2009 10:47 PM
Problem ID 56570 http://www.plus.net/supportpages.html?a=2
Message 16 of 23
(415 Views)
Re: Can't connect
18-05-2009 11:36 PM
Interesting. When I called at around 12:37am, I was told it was a BT issue and definitely not a +net problem, which is obviously now not the case.
Message 17 of 23
(415 Views)
Re: Can't connect
19-05-2009 9:41 AM
Hi Dave,
We weren't aware of the impact of the problem until around 7am yesterday. We'd had an isolated authentication fault raised late on the previous evening, but that's not really that abnormal. Once we started to realise the impact of the problem, the CSC called out our Networks Team and raised a service status post. Following investigation, it appeared that there was a line card fault on one of our gateways. Because it was our newset gateway, we had "double entries" applied in RADIUS to ensure that this pipe was balanced more quickly. However, this also compounded the issue because more customers were trying to connect to the same pipe. We then removed the double entries, fixed the line card and then all seemed to be back to normal.
I'm sorry you were affected.
Quote from: weirddave So, exactly what was the issue and why did it take 11 hours to fix?
Message 18 of 23
(415 Views)
Re: Can't connect
19-05-2009 10:39 AM
Quote from: orbrey Hi mapletree,
that's essentially what we did do, and what resolved the problem this morning. Have you had connection issues this afternoon?
It was OK in the afternoon. All I was asking is, when there is a problem with a single gateway, the usual advice is to reboot modem/router and connect to another gateway. I wonder why this did not work during the morning?
Message 19 of 23
(415 Views)
Re: Can't connect
19-05-2009 11:02 AM
Quote Because it was our newset gateway, we had "double entries" applied in RADIUS to ensure that this pipe was balanced more quickly. However, this also compounded the issue because more customers were trying to connect to the same pipe. We then removed the double entries, fixed the line card and then all seemed to be back to normal.
Message 20 of 23
(415 Views)
Re: Can't connect
19-05-2009 11:16 AM
Thanks for the reply. I've no idea what it means though.
Message 21 of 23
(415 Views)
Re: Can't connect
19-05-2009 11:19 AM
Ok - Basically when we have a new pipe or segment lit, we want to get as many people on it as quickly as possible, so that our network is nicely balanced.
We do this by adding double entries. What this means is that instead of new connections to us being shared across all of our gateways, more customers will be directed onto the pipe/segment with double entries. It's pretty common practice, but caused the problem to be a bit more widespread because a large number of customers were being directed to the pipe with the dodgy line card.
Message 22 of 23
(415 Views)
Re: Can't connect
19-05-2009 5:02 PM
I get it now
Message 23 of 23
(415 Views)
- « Previous
- 1
- 2
- Next »
