Can't connect to internet
- Re: Can't connect to internet
22-07-2014 10:05 AM
Why do I keep getting this message with your logo on it:
"Technicolor TG582n
Login !
Login
Enter your username and password to access your Technicolor Gateway.
Username:
Password: "
Every time I try to go to any site?
Or: "this page is unavailable"? Theses pages include Google, BAILLI, Googlemail, my bank accounts, etc, etc. I've tried sending a meter reading to my suppliers, but same thing.
It started yesterday. I've run Avast anti-virus; I've run the CCleaner; I've now (with no little difficulty) reached you. I am trying to book flights, car etc for next month. The prices keep changing, because, as I try to go from screen ton screen, this message comes up.
What is going on?
Regards, MF
"Technicolor TG582n
Login !
Login
Username:
Password: "
What is going on?
Regards, MF
Message 1 of 5
(1,127 Views)
4 REPLIES 4
22-07-2014 10:17 AM
Welcome to the forums
Can we do a few checks first
Which lights on the router are green and which are red as it sounds as though you have lost your internet connection or the broadband connection
Message 2 of 5
(703 Views)
22-07-2014 1:42 PM
None red.
Message 3 of 5
(703 Views)
22-07-2014 1:46 PM
Are there any unlit ones - alternatively are they all green
Have you tried rebooting the router
Message 4 of 5
(703 Views)
23-07-2014 11:20 AM
Hi mf2cd1,
Welcome to the forum. As you can see from the picture below, your connection is dropping quite frequently, it's likely that your seeing this screen when your disconnected.
On further investigation it appears that something happened on the 13th of July that has caused your connection to deteriorate. If you aware of anything that could have happened on that day either internal or external then it could help us pinpoint the root cause.
It's possible that your router is the cause of the problem, it would be really helpful if you could try another. If you continue to experience drops/slow speeds then please test your connection by plugging your router into the test socket with a different filter.
<img src="http://community.plus.net/visualradius/generated/image14061086957334.png"/>
Message 5 of 5
(703 Views)
