Can't connect to Facebook or YouTube
- Can't connect to Facebook or YouTube
06-03-2014 11:30 PM
I try to go to Facebook and all I get is an update flash message which I can't get passed. I know flash is up to date and it can't be my computer at fault as the same thing happens on my android tablet and Nokia phone which is running Linux, both of which can't run flash anyway.
Very odd.
Rebooting computer and router doesn't work.
Re: Can't connect to Facebook or YouTube
07-03-2014 6:11 AM
http://www.scmagazine.com/poisoned-youtube-ads-serve-caphaw-banking-trojan/article/335465/
You could try something like the free AdblockPlus
Or it may be worth
D/Loading & installing the free Malwarebytes Antimalware to check if you have any malware
Also make sure you have the latest version of your Web Browsers
If for example you use Chrome & have the latest FlashPlayer for that, yow may also have to install the latest FlashPlayer for other Browsers like IE (I know a pain but needs to be done on some systems)
07-03-2014 8:53 AM
07-03-2014 9:23 AM
Can you check the DNS servers in your router (let me know if you don't know how)?
07-03-2014 9:30 AM
Don't know how to check DNS Servers
07-03-2014 9:38 AM
I was wondering if it might be related to this - http://www.pcworld.com/article/2104380/attack-campaign-compromises-300000-home-routers-alters-dns-se...
But I would doubt it now seeing as you have a different router.
07-03-2014 10:24 AM
07-03-2014 10:46 AM
07-03-2014 11:15 AM
07-03-2014 11:19 AM
07-03-2014 11:51 AM
07-03-2014 12:49 PM
Are you using Firefox?
07-03-2014 1:15 PM
07-03-2014 1:17 PM
Secure Connection Failed
An error occurred during a connection to apps.facebook.com. SSL received a record that exceeded the maximum permissible length. (Error code: ssl_error_rx_record_too_long)
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem. Alternatively, use the command found in the help menu to report this broken site.
07-03-2014 2:24 PM
Our DNS addresses are: 212.159.6.9 and 212.159.6.10
