Can't connect to ArsTechnica.com
- Re: Can't connect to ArsTechnica.com
05-11-2014 8:26 PM
I've been unable to connect to www.arstechnica.com for about a week now.
- I haven't found any other websites that are out e.g. bbc.co.uk loads fine
- ArsTechnica.com itself is fine (I can load it on my mobile over 3g), I just can't access it from plus.net
- The problem has been around for several days.
I include a traceroute below showing where things go wrong. Hopefully someone can use that?
Cheers,
John.
> PING arstechnica.com (50.31.151.33): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
^C
--- arstechnica.com ping statistics ---
6 packets transmitted, 0 packets received, 100.0% packet loss
> traceroute arstechnica.com
traceroute to arstechnica.com (50.31.151.33), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 1.720 ms 1.153 ms 1.133 ms
2 lo0.10.central10.ptn-bng02.plus.net (195.166.130.190) 9.430 ms 8.759 ms 8.440 ms
3 irb.10.ptw-cr01.plus.net (84.93.249.1) 8.339 ms
irb.10.ptw-cr02.plus.net (84.93.249.2) 9.339 ms 7.944 ms
4 te-4-2.car5.london1.level3.net (217.163.45.249) 7.960 ms 8.345 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 16.524 ms
5 ae-1-51.ear1.chicago2.level3.net (4.69.138.137) 100.170 ms
te-3-4.car5.london1.level3.net (217.163.45.181) 8.470 ms
ae-1-51.ear1.chicago2.level3.net (4.69.138.137) 98.160 ms
6 ae15.cr1.ord6.scnet.net (4.35.108.230) 118.450 ms
ae-1-51.ear1.chicago2.level3.net (4.69.138.137) 123.497 ms
xe-11-1-0.edge3.london2.level3.net (212.187.201.209) 8.321 ms
7 ae15.cr1.ord6.scnet.net (4.35.108.230) 110.454 ms 110.308 ms
71.ae1.ar1.ord6.us.scnet.net (204.93.204.153) 106.184 ms
8 * * 71.ae1.ar1.ord6.us.scnet.net (204.93.204.153) 217.553 ms
9 ae15.cr1.ord6.scnet.net (4.35.108.230) 169.779 ms * *
10 * * *
11 * * *
^C
Cheers,
John.
^C
10 * * *
11 * * *
^C
Message 1 of 9
(2,332 Views)
8 REPLIES 8
05-11-2014 8:58 PM
Very strange as the site isn't down at all. Try clearing your Internet Browser Cache and perhaps any Cookies related to that site and give it another try.
Message 2 of 9
(1,132 Views)
05-11-2014 9:07 PM
The ping and traceroute don't show anything wrong, it's just that the website doesn't respond to ping. A working traceroute doesn't look significantly different:
[tt]# traceroute -T -p 80 arstechnica.com
traceroute to arstechnica.com (50.31.151.33), 30 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 3.970 ms 5.186 ms 5.364 ms
2 lo0-central10.ptw-ag01.plus.net (195.166.128.195) 37.758 ms 38.083 ms 38.763 ms
3 link-b-central10.ptw-gw02.plus.net (212.159.2.146) 25.786 ms 27.998 ms 28.165 ms
4 xe-4-2-0.ptw-cr02.plus.net (212.159.0.242) 30.301 ms 32.173 ms 32.387 ms
5 ae1.pcl-cr02.plus.net (195.166.129.3) 93.682 ms ae2.ptw-cr01.plus.net (195.166.129.4) 33.051 ms ae1.pcl-cr02.plus.net (195.166.129.3) 34.726 ms
6 te-4-2.car5.London1.Level3.net (217.163.45.249) 37.051 ms 22.322 ms *
7 xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) 23.412 ms xe-11-1-0.edge3.London2.Level3.net (212.187.201.209) 21.119 ms *
8 * ae15.cr1.ord6.scnet.net (4.35.108.230) 135.284 ms *
9 * 71.ae1.ar2.ord6.us.scnet.net (204.93.204.157) 113.062 ms 71.ae1.ar1.ord6.us.scnet.net (204.93.204.153) 116.140 ms
10 carstechnica.com (50.31.151.33) 111.347 ms ae15.cr1.ord6.scnet.net (4.35.108.230) 127.816 ms 127.902 ms[/tt]
Message 3 of 9
(1,132 Views)
05-11-2014 9:27 PM
Hi
What are the first 2 octects of your IP address (eg 84.93.x.x)?
Plusnet Staff - Lead Network Design/Delivery Engineer
Message 4 of 9
(1,132 Views)
05-11-2014 9:29 PM
146.199.xxx.xxx
Message 5 of 9
(1,132 Views)
05-11-2014 9:36 PM
Thanks Strat, wish that button worked for me.
Looks like that is one of the newer IP ranges, the website may maintain their own GeoIP database, the OP should try a gateway hop and test again.
Message 6 of 9
(1,132 Views)
05-11-2014 9:54 PM
Thanks. How do I do a "gateway hop"?
Cheers.
John.
Cheers.
John.
Message 7 of 9
(1,132 Views)
05-11-2014 11:25 PM
Hi.
I just bounced my router, and now I have an IP address 46.208.xx.xx, and connect via ptn-ag02 (previously ptn-bng02).
I still can't connect to Ars.
I've tried from a fresh account (so no browser cookies), and the trace route still fails one hop short of the successful one posted by ejs.
*** And now its back ***
Thanks for the help.
John.
1 192.168.1.1 (192.168.1.1) 2.565 ms 2.528 ms 5.750 ms
2 lo0-central10.ptn-ag02.plus.net (195.166.128.191) 12.562 ms 11.693 ms 10.471 ms
3 link-b-central10.ptn-gw02.plus.net (212.159.2.134) 19.312 ms 19.761 ms 20.313 ms
4 xe-1-2-0.ptw-cr02.plus.net (212.159.0.114) 21.516 ms 19.650 ms 19.387 ms
5 ae2.ptw-cr01.plus.net (195.166.129.4) 20.101 ms 21.116 ms 21.205 ms
6 ae1.pcl-cr01.plus.net (195.166.129.1) 20.176 ms
te-3-4.car5.london1.level3.net (217.163.45.181) 134.507 ms
te-4-2.car5.london1.level3.net (217.163.45.249) 208.582 ms
7 * * *
8 * ae15.cr1.ord6.scnet.net (4.35.108.230) 106.223 ms 106.220 ms
9 71.ae1.ar2.ord6.us.scnet.net (204.93.204.157) 109.971 ms
71.ae1.ar1.ord6.us.scnet.net (204.93.204.153) 136.337 ms *
10 * ae15.cr1.ord6.scnet.net (4.35.108.230) 111.818 ms 112.456 ms
11 * * 71.ae1.ar2.ord6.us.scnet.net (204.93.204.157) 116.647 ms
John.
7 * * *
Message 8 of 9
(1,132 Views)
06-11-2014 8:41 AM
Rebooting the router drops both the PPP session and sync with the exchange - dropping sync too often can cause the dreaded DLM to the line is unstable and it will lower your speed.
To change gateway you only need to drop the PPP session which you can do by clicking the disconnect button in the router interface and then click connect after about 10 seconds.
Message 9 of 9
(1,132 Views)
