Can't connect - how to check function of fttc modem
- Re: Can't connect - how to check function of fttc ...
19-09-2014 3:49 PM
Cannot connect via Netgear n600 using a fttc modem
Not sure if router or modem is problem (thunderstorm last night)
Router seems ok but not eceiving a signal
How do i check the fttc Bt openreach modem is functioning ok (2 green lights showing)
thanks in advance
j
thanks in advance
j
Message 1 of 3
(937 Views)
2 REPLIES 2
Re: Can't connect - how to check function of fttc modem
22-09-2014 8:57 PM
Still having an issue?
You should have 3 lights on the openreach router
1)Power
2) DSL
3) Lan1/lan2
now if all 3 are solid green your connection to the openreach router is all working fine but if any are flashing apart from lan light you have a problem that will require thorough diagnosing
Hope you have it sort and this message is not needed
1)Power
2) DSL
3) Lan1/lan2
Message 2 of 3
(278 Views)
22-09-2014 9:05 PM
You can test the modem by plugging a PC directly into it and setting up a PPPoE connection.
There's a guide here for Windows 7
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Message 3 of 3
(278 Views)
