Can someone please help me with setting up HH2 on my fibre broadband
- Can someone please help me with setting up HH2 on ...
23-06-2013 1:33 PM
i bought a homehub 2 today from a car boot as we have been having lag issues with our technicolor router,
I found a guide on here which said all you needed to do was type in your plusnet user name and password and it should connect but mine isnt working.
My questions are these
1. the pasword for the broadband is this the same password i used to sign in on the plusnet website? if not how can i find out what it is as its blanked out on the connection info page on plusnets member area
2. when you connect the homehub to the openreach modem do you need to plus into a specific ethernet port?
3 based on point 1 being the log in on website and point 2 being either 1 or 2 for some reason when i go to the page to enter user name and password it just says theres no connection to login to so i then go to advanced settings and it allows me to type int eh username and password but then still nothing happens....
I thought it was meant to be really easy to get a homehub setup on plusnet but for some reason its just not working.
Someoens help would be much appreciated!!!
Paul
Re: Can someone please help me with setting up HH2 on my fibre broadband
23-06-2013 2:00 PM
Yes
Quote the pasword for the broadband is this the same password i used to sign in on the plusnet website?
The HH2 was primarily designed for an ADSL and not Fibre connection. I think the HH 2.0b did have the ability to be used with Fibre, LAN port 4 was the correct one to use I believe.
With a HH 2.0a the only way is to unlock it http://www.psidoc.com/showthread.php/7-How-to-hack-or-unlock-your-home-hub-2.0A-via-software. and then reconfigure port 4 for Fibre use http://www.psidoc.com/showthread.php/204-Converting-your-Homehub-2.0a-for-use-with-infinity-and-or-V....
Hope that helps
23-06-2013 2:13 PM
24-06-2013 10:06 AM
Quote Ok cool so if i buy a type b it will just be a case of enter username and password
It should be fairly straight forward.
Quote we have been having lag issues with our technicolor router,
I'm just curious as to what happened there exactly as lag issues are not usually hardware related, with that in mind make sure you let us know if you see any similar issues with a new router in place.
Adam
24-06-2013 10:18 AM
24-06-2013 10:26 AM
I'm not sure whether there are 2 versions of firmware for the Type B , an ADSL one and an Infinity(Fibre) one. You might be better off trying to get a HH3 which support Fibre natively.
Jaggies beat me to it...
26-06-2013 9:01 AM
I am hoping this will increase the throughput and therefore at the busy times the extra throughput will counter the high latency i have been suffering on some evenings at peak times
Quote from: _Adam_Walker_
Adam
26-06-2013 11:10 AM
30-06-2013 9:34 AM
Quote from: madtazzy
Was it ths guid created by me? http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
30-06-2013 9:37 AM
I currently have a bt hub 4 on ADSL and is getting ready for fibre
