Can someone drop my net so i can get the speed increase?
- Can someone drop my net so i can get the speed inc...
30-01-2015 7:05 AM
BT Speedtest:
Download speed achieved during the test was - 2.07 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.32 Mbps
Upload speed achieved during the test was - 0.32Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
Plusnet Current line speed:
2.3 Mb
As you know I cannot do this via my router so it has always been done by someone at Plusnet (not drop the line mind, I don't want to increase my SNR)
SNR Margin (dB): 3.4 11.0
Attenuation (dB): 65.0 38.2
Output Power (dBm): 13.0 0.0
Attainable Rate (Kbps): 3192 452
Rate (Kbps): 2624 371
2.3 Mb
Message 1 of 6
(1,153 Views)
5 REPLIES 5
Re: Can someone drop my net so i can get the speed increase?
30-01-2015 8:23 AM
I can't see what's wrong with those stats - your speed looks better than would be expected for your attenuation.
Message 2 of 6
(628 Views)
30-01-2015 9:49 AM
I assume that your IP profile increased recently but the increase in the Plusnet current line speed didn't trigger a PPP drop so your actual speed is a bit lower than you would expect
Are you sure that there wasn't an automatic PPP drop
Message 3 of 6
(628 Views)
30-01-2015 12:16 PM
What's wrong with those stats is the low upstream rate and high upstream SNR margin.
Message 4 of 6
(628 Views)
30-01-2015 6:11 PM
I'm assuming someone dropped my line?
Jan 30 12:20:53 user crit kernel: ADSL link down
Jan 30 12:20:58 daemon crit pppd[14760]: Clear IP addresses. Connection DOWN.
Jan 30 12:20:58 daemon crit pppd[14760]: Clear IP addresses. PPP connection DOWN.
Jan 30 12:22:41 user crit kernel: ADSL G.994 training
Jan 30 12:22:48 user crit kernel: ADSL G.992 started
Jan 30 12:22:52 user crit kernel: ADSL G.992 channel analysis
Jan 30 12:22:59 user crit kernel: ADSL link down
Jan 30 12:23:04 user crit kernel: ADSL G.994 training
Jan 30 12:23:11 user crit kernel: ADSL G.992 started
Jan 30 12:23:15 user crit kernel: ADSL G.992 channel analysis
Jan 30 12:23:22 user crit kernel: ADSL link up, interleaved, us=728, ds=2384
Jan 30 12:23:27 daemon crit pppd[14760]: PPP LCP UP.
Jan 30 12:23:28 daemon crit pppd[14760]: Received valid IP address from server. Connection UP.
and now BT Line stats have lowered?
SNR Margin (dB): 3.4 6.1
Attenuation (dB): 66.5 38.1
Output Power (dBm): 12.9 0.0
Attainable Rate (Kbps): 2988 728
Rate (Kbps): 2384 728
Plusnet current line speed: 2.3 Mb
BT Speed test
BT Speed test
Message 5 of 6
(628 Views)
30-01-2015 6:36 PM
I doubt it was anyone at Plusnet unless someone did a line test. The downstream speed is lower but the upstream speed is up to a more usual value.
Message 6 of 6
(628 Views)
