Can plusnet lock your SNR?
mattstead
My default SNR seems to be at the usual 6db (or at least it tries to be),  This seems suprising considering how far I am from the exchange....one of the many BT engineers who have been out said he expected me to be running at 12db. So is it possible for plusnet to set my target SNR at a higher amount? I only ask this as my SNR is still all over the place (after about 8 visits, a new cable to the road, and a lift and shift at the exchange), and I was thinking that if my SNR started higher then when it drops dramatically it is less likely to drop to an unacceptable level.
I know that raising the SNR will reduce my speed, but due to the instability my IP profile has been at 135K for the 3 months since joining plusnet, so the added stability might get my speed up...if it's possible to lock the SNR.?
16 REPLIES 16
HPsauce
Re: Can plusnet lock your SNR?
Almost any ISP can set a target SNR which is used at sync time.
The default on most is 6dB but it can be higher, e.g. 9 or 12dB.
DLM can also change it, not sure how that would interact though.
Obviouslt the actual SNR changes during a "session" as conditions change.
mattstead
Thats's promising then..I expect the SNR to change throughout a session, I just hope that if it starts from a much higher level then it might just be stable.
knowdice
Higher SNR will be more stable especially on a long line, this will of course be at the expense of speed.
i.e. a 6dB higher SNR will half your sync speed  Embarrassed
itsme
Quote from: knowdice
Why do you know it will half the speed? You are not getting confused with power when -3dB drop the power by half.
knowdice
3dB for power.
6dB for voltage ratio.
itsme
Yes but it does not apply to broadband speed.
knowdice
Pretty sure it does.
Strat
Fixes: 565
Quote from: http
Each line needs a specific amount of SNR to run at a given speed. Very roughly its often said that 1dB of SNR equates to 450kbps of speed, but other factors such as attenuation and output power need be bourne in mind and some lines may only see around 1Mb per 3dB.
itsme
You are aware that what being discussed here is a SNR margin. Not the actual SNR.
knowdice
What I'm saying is whilst there are a lot of factors that determine the actual speed your router actually syncs at.
If for example you are on a long line and with a target SNR of 6dB and you get say 2mbs download sync, if you change the target SNR to 12dB then the sync speed will drop to 1mbs.
dick:quote
HPsauce
That's not inconsistent with the Kitz observation.  Wink
On shorter lines at higher speeds you will definitely NOT get a halving of connection speed by such a change.
Best thing is to try it and see what the effects are.  Cool
billnotben
You could also just reconnect when your snr is low, which would basically have the same end result.
wisty
Fixes: 8
If you use a Netgear 834 with the DGTeam firmware you can ask the router to negotiate a higher (or lower) SNR, and the change survives a router restart.
gyre
I've had some wierd effects with the DLM and changing target SNR margins with the broadcom chipset in the past.
Starts off as expected, but then it seems on the next resync to need a bit more reduction and then a bit more just to keep the same margin.
I could start off at 80% to get to the target SNR margin I wanted, but then a few resyncs later I'm on 40% to get the same effect.  Almost as if the BT DLM mechanism is fighting me.
-- gyre --
