Can my IP profile be increased quickly?
- Can my IP profile be increased quickly?
- « Previous
- Next »
Re: Can my IP profile be increased quickly?
13-05-2009 10:19 AM
I'd guess an interim response along the lines of "things seem slightly improved, I'll continue to monitor for a while".
When you have time, post the latest RouterStats NoiseMargin graph. (Did you have any luck with screws?)
13-05-2009 11:52 AM
There is quite a lot on the ticket but to summerise they could not find a fault but noted that the sync speed was slower than expected.
I got a long reply with all the obvious things to try and then an offer of a large bill from BT.
I haven't replied since I discovered the problem with the cable. I'm not at home much but I will post a graph ASAP. (I haven't had time to visit a shop so the screw is still missing.)
13-05-2009 8:07 PM
13-05-2009 8:44 PM
That said it's also worth looking at the possibility of electrical interference. Go round and switch off all electical appliances in turn, all energy saving lamps, fluorescents, including the transformer for halogen lights, power packs for anything (other than the router!) even your monitor and watch the noise plot and see if that variation stops.
HTH.
14-05-2009 8:11 AM
I've tried turning things off as you suggested, but it did not make any difference.
14-05-2009 3:41 PM
14-05-2009 7:13 PM
I am out of ideas on other possible causes. Every time I have a theory and test it, it proves to be wrong. If it is close neighbours causing the problems then I don't know how I could do anything about it.
I have attached some of the more recent graphs. I haven't got any daytime graphs because I am not in during the day. Note that the disconnection on the 11th is my fault and can be ignored.
16-05-2009 3:32 PM
16-05-2009 4:18 PM
16-05-2009 4:34 PM
16-05-2009 6:02 PM
17-05-2009 9:52 AM
17-05-2009 4:34 PM
I know this will be tedious. irritating etc, as you'll no doubt have to reset any electric clocks and the like, but turn of as many circuits as you can at your main distribution board, obviously you'll have to keep the power on to the sockets your router is on, but try unplugging/switching off everything else. See if you can find any difference.
If that's what you've already done, then were are down to a line problem or REIN/RFI neither of which will be especially easy to nail down under present circumstances (on the assumption you tried one of your other modem/routers again and the problem is still there).
18-05-2009 5:25 PM
- « Previous
- Next »
