Can i use a BT-HUB5 instead of my plusnet router ?
- ADSL Broadband
- Can i use a BT-HUB5 instead of my plusnet router ?
14-09-2018 10:19 AM
Is it possible to to a BT Homehub 5 rather than my plusnet supplied router ?
Have been with PN for 2 years and recently my other half has had problems with work VPN connectivity (Juniper VPN); mine works fine but is different software. work tech support are saying is a known issue with the plusnet router not negotiating the secure connection (dont have exact details to hand) and have closed the case saying not their problem.
We know it worked fine before when we were on BT using their hub.
Thoughts ?
Re: Can i use a BT-HUB5 instead of my plusnet router ?
14-09-2018 10:23 AM - edited 14-09-2018 10:30 AM
Yes
https://www.plus.net/help/broadband/broadband-connection-settings/
see thread
https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/m-p/1192234
and for The BT Smart Hub 6 see
https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
(Do not use any &*". or similar in passwords though)
- ADSL Broadband
