Can i replace my technicolour wireless router with a TP link tl-wa901nd?
- Can i replace my technicolour wireless router with...
08-06-2013 10:31 AM
Hiya
I have a tl-wa901nd wireless access point sitting around the house and its becoming apparent to me after hearing back from plusnets engineers that a lot of my speed is being lost through the poor technicolor modem we have been provided.
so my question is is it possible to replace the technicolor router with my access point as i know from experience that this has excellent wireless range and speed.
If so if there a guide i can follow to set it up?
Thanks a lot in advance
Madtazzy
Madtazzy
Message 1 of 3
(811 Views)
2 REPLIES 2
Re: Can i replace my technicolour wireless router with a TP link tl-wa901nd?
08-06-2013 10:45 AM
It won't work as it is an access point only
However you could link it to the Technicolor using the ethernet port and use it for wireless access
Message 2 of 3
(292 Views)
10-06-2013 11:23 AM
If you do do that (and it sounds like it might be worth it) best to turn off the wireless network in the router as there'll be no need for it.
Message 3 of 3
(292 Views)
