Can broadband speeds get stuck?
- Can broadband speeds get stuck?
18-03-2010 3:31 PM
I think my broadband speed has got stuck. Can this happen or can anybody see a reason for it?
Router stats
BusyBox v1.00 (2008.08.14-04:05+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 861 Kbps, Downstream rate = 2976 Kbps
Link Power State: L0
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 14.9 6.2
Attn(dB): 50.0 28.8
Pwr(dBm): 0.0 13.0
Max(Kbps): 6236 864
Rate (Kbps): 2976 861
G.dmt framing
K: 47(0) 124
R: 16 0
S: 1 1
😧 64 1
ADSL2 framing
MSGc: 59 10
B: 46 123
M: 1 1
T: 2 1
R: 16 0
S: 0.5000 4.5714
L: 1008 217
😧 64 1
Counters
SF: 736170 664508
SFErr: 0 0
RS: 95702180 0
RSCorr: 660 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 83960141 1176553
Data Cells: 978636 118
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 33 0
AS: 11963
INP: 4.06 0.00
PER: 16.25 18.28
delay: 8.00 1.14
OR: 32.00 7.00
Bitswap: 4 0
Total time = 3 hours 20 min 13 sec
SF = 736170
CRC = 0
LOS = 0
LOF = 0
ES = 0
Latest 1 day time = 3 hours 20 min 13 sec
SF = 736170
CRC = 0
LOS = 0
LOF = 0
ES = 0
Latest 15 minutes time = 5 min 13 sec
SF = 19319
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 55366
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 55365
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 55428
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 55365
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 8000
Last Retrain Reason: 8000
Bt speed tester
Download speedachieved during the test was - 2513 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :2976 Kbps(DOWN-STREAM), 861 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.07:24.39:57.54 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Router stats
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Down Up
SNR (dB): 14.9 6.2
Attn(dB): 50.0 28.8
Pwr(dBm): 0.0 13.0
Max(Kbps): 6236 864
G.dmt framing
K: 47(0) 124
R: 16 0
S: 1 1
😧 64 1
ADSL2 framing
MSGc: 59 10
B: 46 123
M: 1 1
T: 2 1
R: 16 0
S: 0.5000 4.5714
L: 1008 217
😧 64 1
Counters
SF: 736170 664508
SFErr: 0 0
RS: 95702180 0
RSCorr: 660 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 33 0
AS: 11963
INP: 4.06 0.00
PER: 16.25 18.28
delay: 8.00 1.14
OR: 32.00 7.00
Bitswap: 4 0
SF = 736170
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 736170
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 19319
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55366
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55365
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55428
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55365
CRC = 0
LOS = 0
LOF = 0
ES = 0
Bt speed tester
Message 1 of 7
(1,187 Views)
6 REPLIES 6
Re: Can broadband speeds get stuck?
18-03-2010 3:41 PM
Your connection rate matches what your ip profile should be
Message 2 of 7
(635 Views)
18-03-2010 4:22 PM
My router says the SNR is 14.9 it is always around 15 so I thought my connection rate should be higher.
It also say the max is "Max(Kbps): 6236" and I am only getting half of that.
Message 3 of 7
(635 Views)
18-03-2010 4:37 PM
The SNRM of around 15dB is rather high as the default set by the DSLAM is usually around 6dB so there must be a noise issue on your line.
If that issue isn't permanent on your line then over the next 14 days or so (without any resyncs happening) the 15dB might end up near the 6dB figure which should allow for a higher sync rate and in turn faster speeds some of the time
Message 4 of 7
(635 Views)
18-03-2010 4:39 PM
The higher the SNR is, the lower the sync rate will be - however your SNR will only lower if the exchange equipment deems the line stable enough (unless you have a router capable of setting the SNR value itself).
EDIT: too slow, apparently
Message 5 of 7
(635 Views)
18-03-2010 4:58 PM
I am capable of setting the SNR value using telnet, I am not sure if I want to do that just yet though (I don't know what effect it will have). Is there any programs around that will monitor how much noise I have on the line? Then I can leave it running and capture data and if there is not a lot of noise change it myself.
Message 6 of 7
(635 Views)
18-03-2010 5:02 PM
routerstats and routerstats lite are good, helped me lot by understanding my line.
Message 7 of 7
(635 Views)
