Can anyone recommend a new router please??????
dave141070
I just recently got fibre optic broadband from Plusnet and have the standard TG582n router, I should be getting speeds of up to 71mbps but instead i get anything from 0.23mbps (yes this is correct) to 52mbps although it is usually around the 10mbps, i should be getting a lot more and i think this may be because of the router, can anyone please recommend a new router model that can handle up to 71mbps with a good signal range?
I have run speed tests with thinkbroadband and bt speedtester on 3 different pc's and with thinkbroand tests the speeds are always very varied but usually low yet with bt speed tester they were high - always around 60mbps
However internet speeds do not feel as fast as bt sppedtester makes out
Help is appreciated
3 REPLIES 3
Oldjim
Resting Legend
Fixes: 63
Re: Can anyone recommend a new router please??????
Almost duplicate post in another thread removed to keep all the replies in one place
Are those speed results wired or wireless
dave141070
Hi
Thanks for reply
They were wired to router
dave141070
I do think the problem is wireless yet because we have tested on different machines this leads me to believe that it is the router at fault
