Can anyone recommend a new router please??????
- Re: Can anyone recommend a new router please??????
21-09-2012 9:59 AM
I just recently got fibre optic broadband from Plusnet and have the standard TG582n router, I should be getting speeds of up to 71mbps but instead i get anything from 0.23mbps (yes this is correct) to 52mbps although it is usually around the 10mbps, i should be getting a lot more and i think this may be because of the router, can anyone please recommend a new router model that can handle up to 71mbps with a good signal range?
I have run speed tests with thinkbroadband and bt speedtester on 3 different pc's and with thinkbroand tests the speeds are always very varied but usually low yet with bt speed tester they were high - always around 60mbps
However internet speeds do not feel as fast as bt sppedtester makes out
Help is appreciated
Help is appreciated
Message 1 of 4
(905 Views)
3 REPLIES 3
21-09-2012 10:09 AM
Almost duplicate post in another thread removed to keep all the replies in one place
Are those speed results wired or wireless
Message 2 of 4
(393 Views)
21-09-2012 11:15 AM
Hi
Thanks for reply
They were wired to router
Thanks for reply
Message 3 of 4
(393 Views)
21-09-2012 11:17 AM
I do think the problem is wireless yet because we have tested on different machines this leads me to believe that it is the router at fault
Message 4 of 4
(393 Views)
