Can I have a dialup as well as broadband?
- Can I have a dialup as well as broadband?
14-08-2007 2:51 PM
I have two email addresses with Orange (Freeserve) and I have set Thunderbird to collect messages from Freeserve, so I that I do not have to register on several forums. These addresses are on Pay-as-U-Go dial up connections, which have to be dialed every 3 months otherwise the ISP would terminate them.
I could create dialup connection in a matter of minutes on this computer, but would that cause problems with broadband?
Thanks,
Alex
Thanks,
Alex
Message 1 of 7
(2,449 Views)
6 REPLIES 6
Re: Can I have a dialup as well as broadband?
14-08-2007 2:54 PM
I do it all the time (well every 6 weeks) - no problem as long as it isn't a PlusNet dialup
Message 2 of 7
(594 Views)
14-08-2007 3:15 PM
Thank you Jim,
Alex
cp:blue Please do not quote the full preceding post. See Forum Rules, Use of Quotes mod:end
Alex
Message 3 of 7
(594 Views)
14-08-2007 7:20 PM
Best to plug the dial-up modem in via the 'telephone' side of a microfilter though if you don't want it to interrupt the broadband connection.
Message 4 of 7
(594 Views)
14-08-2007 7:23 PM
I didn't think you could plug it into the wrong slot as it won't fit - at least it doesn't on my connector
Message 5 of 7
(594 Views)
14-08-2007 10:21 PM
It does if you unplug the lead from the back of the ADSL modem and plug it into the dial-up modem
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 6 of 7
(594 Views)
14-08-2007 10:27 PM
Now that would really mess up your broadband connection
Message 7 of 7
(594 Views)
