Can I get my ADSL Upload Uncapped?
- Re: Can I get my ADSL Upload Uncapped?
31-01-2015 3:28 PM
hi - i've been struggling to upload to iCloud and Facetime is kinda painful so checked out speedtest. Download is awesome 11.85Mbps - Upload is pants! 0.23Mbps Can I get this uncapped?
thanks
Stats...........
Link Information
Uptime: 45 days, 19:58:01
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 13,783
Data Transferred (Sent/Received) [GB/GB]: 16.67 / 194.14
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 13.6 / 24.5
SN Margin (Up/Down) [dB]: 30.0 / 6.7
Loss of Link (Remote): -
Error Seconds (Local/Remote): 352,695 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 83 / 2,776,190
HEC Errors (Up/Down): 37 / 15,907,133
thanks
Stats...........
Link Information
Message 1 of 9
(1,246 Views)
8 REPLIES 8
31-01-2015 3:32 PM
that is bad even for a capped line - can you post the router stats as requested here http://community.plus.net/forum/index.php/topic,96155.0.html
Message 2 of 9
(764 Views)
31-01-2015 3:33 PM
The upstream is showing as capped. I'll go place an order to remove the cap, the order should complete on Tuesday.
Message 3 of 9
(764 Views)
31-01-2015 3:43 PM
nice one - look forward to it
and thanks for repsonding so quickly
Message 4 of 9
(764 Views)
31-01-2015 3:45 PM
From the stats - no obvious reason for the rubbish upload in the test
Let's see what happens after it is uncapped
Message 5 of 9
(764 Views)
31-01-2015 3:53 PM
thanks - appreciate it
Message 6 of 9
(764 Views)
07-02-2015 11:27 AM
Hi - upload speed seems to have improved - i'm getting 1.00Mbps - havent tested iCloud/Facetime yet but theoretically should be 5 times faster! Is this about right for uncapped?
cheers
New stats...
Uptime: 4 days, 9:50:18
Bandwidth (Up/Down) [kbps/kbps]: 1,259 / 14,790
Data Transferred (Sent/Received) [GB/GB]: 26.59 / 225.99
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 13.5 / 25.0
SN Margin (Up/Down) [dB]: 5.8 / 5.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 391,812 / 0
CRC Errors (Up/Down): 40 / 99,849
HEC Errors (Up/Down): 26 / 317,551
cheers
New stats...
Message 7 of 9
(764 Views)
07-02-2015 11:35 AM
Hey,
On ADSL your never going to get higher than 1.00Mbps.
Unless annex m is available on a business line only.
So it looks like the uncap order completed.
Message 8 of 9
(764 Views)
07-02-2015 11:40 AM
okay nice one - thanks for confirming
Message 9 of 9
(764 Views)
