Can I get fibre?
- Re: Can I get fibre?
Can I get fibre?
02-02-2013 6:38 PM
Someone has worked hard to make it difficult for me to find the answer to this question. Can anyone here tell me how I ccan find out if fibre broadband is available on my phone line?
Message 1 of 7
(1,133 Views)
6 REPLIES 6
02-02-2013 6:46 PM
If you enter the details in "check what's available" on the Plusnet home page it will give you the answer or, if you are already with Plusnet, direct you to "change my products", where you can see what is available.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 2 of 7
(616 Views)
02-02-2013 6:49 PM
The other way is https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch... which may be more informative
Message 3 of 7
(616 Views)
02-02-2013 7:22 PM
Quote from: PeeGee If you enter the details in "check what's available" on the Plusnet home page it will give you the answer or, if you are already with Plusnet, direct you to "change my products", where you can see what is available.
So if no "fibre" options appear I should assume it is not available to me?
Message 4 of 7
(616 Views)
02-02-2013 7:39 PM
Oldjim:
https://www.btwholesale.com/includes/adsl/main.html goes directly to the checker page, but the information is essentially the same as Plusnet.
anotherbob:
Yes, no fibre option is no fibre. You can find your exchange through http://www.samknows.com/broadband/exchange_search and may find when/if it is to be enabled.
anotherbob:
Message 5 of 7
(616 Views)
02-02-2013 7:57 PM
That assumes that the Plusnet information is up to date and it sometimes isn't and it also gives a bit more information such as the cab you are connected to
Message 6 of 7
(616 Views)
03-02-2013 2:48 PM
Is there anyway to work out where the cabinet number on the BT Checker oldjim supplied th link for? i.e. a map of them somewhere?
Message 7 of 7
(616 Views)
