Can I connect my wireless router to my network hub via Wi-Fi
- Can I connect my wireless router to my network hub...
Re: Can I connect my wireless router to my network hub via Wi-Fi
26-05-2013 6:00 PM
Quote from: Pictureman1 I have since noticed that myself since in every other case it is 69 I can only assume that I mode a reading or transcription error, also both sets of figures in 2) were also taken using the same t/p extemnsion socket with any changes being with the cables at the router end, I do have an IDC tool but based on the checks when removing the bell wires I am quite happy on this point.
You should not happy. If the attenuation is 63dB at the master socket then it should still be no more than 64dB elsewhere in the house (and that only because your router reads with 1 dB resolution). If it's really 69dB at the extension socket but 63dB at the master socket then you have a very bad contact or an almost broken wire somewhere. 6dB (=69-63dB) is roughly one quarter, which means the signal strength at your extension socket is one quarter the signal strength at the master socket.
27-05-2013 7:01 PM
Have now carried the quiet line check with a better listening ear than my own no problen in that respect, also regard the question on my DIY skills, I would have no problem in normal circumstances, however the construction (chipboard floors stone front cladding etc would make it rather difficult so would rather go along the lines previously discussed if I can prove the internal wireing is faulty and I can do nothing to remedy an existing fault. I think I need to re terminate each end of the cable to the ext skt and see if that improoves things.
Reed in your last reply you said I should be concerned, yes you are right I should be concerned at a 6 db loss, in the above paragraph I have picked up on your concern and will be reterminating the extension ASAP. I did earlier today attach the laptop and spare router to second ext skt we have and that gave a 63 db attenuation seeming to confirm that the other ext has a problem, however I have now connected an extension cable ( constructed from CW1308 cable and IDC terminated jack and socket) between the master skt and the normal router location,that is giving strange results in that it is still showing the high attenuation but does show incresaed download speed. In view of the comments re time to stabilize I am leaving it for a day or so to ensure I get some realistic figures.
27-05-2013 8:24 PM
Missed out the data you asked about routers, one is a Linksys WAG354G, Belkin N150 and Thompson TG585 as supplied by Plusnet
27-05-2013 10:28 PM
Quote from: Pictureman1 In view of the comments re time to stabilize I am leaving it for a day or so to ensure I get some realistic figures.
Last time my sync rate changed it took over six days for Plusnet to catch up. There is really no point in measuring speeds until you have got your internal wiring sorted out. In fact there is no that much point in measuring speeds at all. Your maximum download speed is determined by your router sync rate. A speed test should come close to this maximum unless:
- Some other internet activity is going on that you are unaware of
- There is traffic congestion somewhere en-route
- Plusnet are accidentally throttling your traffic; check your Current Line Speed in the Member Centre
- Your SNRM has dropped so low that you are experiencing a lot of traffic loss
You can check the first, third and fourth of these so if you are careful then a speed test is only meaningful to reveal if you have a problem with traffic congestion.
01-06-2013 9:49 PM
Sorry not to have been active on the forum over the last few days but have not been idle, ran the ext lead I referred to in my post of 27/5 for a couple of days to see what effect it made, rather strange results in that the attenuation stayed at a similar level but D/L speed shoewd an increas of about 10%.
I have now replaced the Belkin router with the Thompson 858 V8 my download speed has progressivly dropped over the last few days as you will see from the table below, the Thompson has been on line about 3 days now,
The following has been copied and pasted from the appropriate page of the router, any comments particularly with regard the reducing D/L speed or any other items of intrest would be most appreciated.
Uptime: 1 day, 6:20:46
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 14,686 / 1,200
Bandwidth (Up/Down) [kbps/kbps]: 670 / 568
Data Transferred (Sent/Received) [MB/MB]: 43.35 / 74.17
Output Power (Up/Down) [dBm]: 12.5 / 16.0
Line Attenuation (Up/Down) [dB]: 40.0 / 69.5
SN Margin (Up/Down) [dB]: 5.0 / 4.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Power (Local/Remote): 0 /
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 17,845 / 44,187
CRC Errors (Up/Down): 178,140 / 38
HEC Errors (Up/Down): 14,465 / NA
Many thanks
02-06-2013 10:30 PM
well as jelv and I have said, waiting for download speeds to change is a bit of a pointless exercise, it's the sort of stats above that one needs to look at, as they immediately show the impact of any changes. But before making any detailed comment on the above, I need to clarify a few things.
In your extension lead, is it just the Blue+white trace and White+blue trace wires connected in the plug/jack end (and I assume the socket end)?
Is/was the Thomson connected via this lead for all that time (3 days) and when the stats were taken?
Also to pick up a couple of points from reply #28 & reply #31
You mentioned about replacing the i-plate with a vDSL plate. There is firstly no point in doing this unless you plan to put the modem/router at the master socket and secondly there is no common-mode filtering of the modem/router connection in the vDSL plate so you would lose any benefit you currently get from the i-plate.
You've mentioned a second extension socket - what colour are the wires on terminals 2 & 5 and are those on the first extension socket the same?
You also mentioned about testing a spare router in the 2nd extension socket, I assume you didn't plug it in at the same time as another was connected in either of the other sockets?
Also you didn't say which one it was, not that it actually matters because it will be like comparing chalk with cheese - you need to use the same modem/router in each socket to make a proper comparison of the figures as different mode/routers use different algorithms to calculate attenuation and noise margin and will produce slightly different figures.
As regards the stats of the 585v8 above, well I'm afraid although they contain all the type of information one would want to see, I'm not sure I actually believe most of them as there are major inconsistencies throughout a lot of the figures. The sync speed figures (Bandwidth) whichever way round they actually are would suggest that the download is half what it was before. I wouldn't recommend using it for any further testing as I'm afraid I believe it's gone faulty.because of the other figures if nothing else.
The Linksys has very poor stats reporting, so I'd suggest using the Belkin, although you haven't said which model it is, I believe it has better stats reporting.
03-06-2013 11:09 PM
I can confirm that the ext lead has just the Bl/Wh and Wh/Bl Connected, however to my untrained eye at least the figures using the ext lead were similar attenuation wise to the normal ext at the computor location, whilst the download speed was initially slightly faster it has shown a steady deterioration to the figure shown in the post, the connection had not been ineterupted during the 3 days. To cofirm a question asked previously the bell circuit has been disconnected at all points within the houshold wiring Master and both ext's.
Yes I am quite willing to locate the router at the master skt provided that there is some speed advantage in doing so, my understanding based on the reply earlier on in the thread was that interstatial vdsl plate would provide isolation from the house wiring your latest reply seems imply my impression is wrong, I assume that I cannot use both the iPlate and the vdsl unit.
Quote Also to pick up a couple of points from reply #28 & reply #31
All extensions and the master socket have been looked at various times and the wiring meets normal coulor coding standards and as stated above the bell wires have been removed at all points. No I can confirm that I did only connect one modem at any one time. Based on your comments I will try to carry out checks again using the same modem at each location.
The Belkin is a N150, a fairly recent if not current model but also quite basic, it does all that is required here but I am not sure that it gives any more than basic stats but will certainly give it a try and see what it does.
I attach below a further set of figures from the Thompson taken this evening, it is now located at the master socket and has been on line about 24 hours.
Information 2200 hrs 3-6-2013 Thompson router Master Skt
Uptime: 1 day, 2:32:45
Maximum Bandwidth (Up/Down) [kbps/kbps]: 14,096 / 1,052
Bandwidth (Up/Down) [kbps/kbps]: 630 / 518
Data Transferred (Sent/Received) [MB/MB]: 21.64 / 181.04
Output Power (Up/Down) [dBm]: 12.5 / 15.5
SN Margin (Up/Down) [dB]: 2.0 / 5.0
FEC Errors (Up/Down): 1,372,337 / 33,501
CRC Errors (Up/Down): 259,197 / 11
HEC Errors (Up/Down): 372,632 / 20
03-06-2013 11:22 PM
04-06-2013 9:05 AM
Thanks for confirming that the wiring to this second extension socket is to the same standard..
Quote .........based on the reply earlier on in the thread was that interstatial vdsl plate would provide isolation from the house wiring your latest reply seems imply my impression is wrong, I assume that I cannot use both the iPlate and the vdsl unit.
I'm afraid I don't think you can use both because the vDSL plate will I believe not physically fit on top of the i-Plate but I don't have one to hand to prove that one way or the other, it might be a simple matter of screw length. The total combination would stick out rather a lot. Yes the vDSL plate will "isolate" by which is meant "filter" the extension wiring, but the effects are usually only noticed when the rest of the wiring isn't the correct standard or defective/problematic in some way. If you have remade all the IDC joints that should have cleared up that aspect and as long as there is no corrosion on any of the sockets or connectors that's another taken care of. The ultimate check is testing which I'll explain more thoroughly in a moment.
With reference to these 585v8 stats, there is several things that particularly concern me, one of which I will address first because of the impact on further testing - that is the Downstream (DS) sync speed or Bandwidth Down as it's called on the Thomson is about half or less of what you had before, this may be because the 585 is defective (I'll come back to that) but it could be because your speed has been "Banded" by the Exchange DLM because of all the Disconnections with checking and testing.
So from now on I'd strongly recommend the following Disconnect method -
Log in to the Modem/Router, in the Internet box (or wherever it show shows ISP login etc), click Disconnect to drop the PPP Internet session (this is not the sync), wait about a minute and then power down the Modem/Router. After about another minute you can unplug it from the line.
Do whatever is needed, swap sockets, filters etc, but stay offline for at least 10 minutes. When you re-connect and power up, Login to the Modem/Router and click Connect to establish a new PPP session.
Don't do this more than 5 times in an hour, then leave it for the rest of the day. This method is to help stop the Exchange DLM from thinking your sync loss was a dropped connection.
If you have a modem/router that doesn't have an interface for you to drop the PPP session, then pull the power plug and wait a minute or two before unplugging from the line.
One further point, especially applicable to very long lines, you will get very small differences in sync speed every time you sync, so just because you get a marginally better sync speed in one situation, it doesn't necessarily mean that situation is better than another situation.
The first set of 585v8 stats there have some very strange values, upstream errors are supposedly enormous compared to the down stream - even on the second set - very unlikely. Error seconds and Loss of Signal are also daft values in the first set - something I know those Thomsons can misreport, but the daftest is the Maximum Bandwidth Up which is 14,686 or 14,096kbps in the 2nd set. There is no way on this earth that you can get those upstream speeds on ADSL2+ or indeed up or down on your connection. All in all I must conclude that the 585v8 may be defective, but is certainly untrustworthy from the point of view of testing. Stick with the Belkin for the time being.
I suggest the following for the next set of tests. Leave the i-Plate in place for all of them, use the same filter, and remember the Disconnect method. Do the tests in daylight hours, ideally somewhere between 1000 & 1600, preferably all within the same hour more or less.
First, plug directly into the i-Plate, power up and grab a set of stats straight away. Leave it 10 minutes and take a second set of stats. Post those when done, straight away if you would.
Remembering the Disconnect method - refit the Front Plate and then plug into the Master Socket and power up. Grab a set of stats straight away and then wait 10 minutes and take a second set of stats and post all those.
Remembering the Disconnect method again, now go to your regular extension socket. Power up and grab a set of stats straight away, leave it 10 minutes and grab another set and post both of them.
If you wish to try your other extension socket, please do, it could be interesting to see what differences there may be in the figures.
We need to check if your Connection Speed has been banded, and if so get it resolved. I'm sure someone from the DCT can do that for us.
04-06-2013 9:19 AM
Sorry Did not pick up the post until this morning. Just done a quiet line test, as I say have a hearing aid which does not help with this, but it really does not seem to have a problem at the moment, did wind the hearing aid up as far as it would go.
04-06-2013 9:42 AM
04-06-2013 2:36 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13703528278642.png"/>
Your line is not currently banded either. It may actually be worth running through our faults checker at http://faults.plus.net
04-06-2013 2:47 PM
05-06-2013 5:00 PM
Sorry not to get back to you yesterday, have now managed to get the set of checks you requested using the Belkin router. As I thought the stats available are only the basics One point that may be of intrest, the router shares the filter with on of the house phones which is a cordless type, I noticed on reconnection after recording your stats that on reconnection there was a worsening of 2-3 db in the downstream noise margin, upstream remains about the same.
All data was taken using the same filter and lead and router.
At iPlate - Wed 5th June - 1132 hrs
ADSL
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 568 630
Noise Margin 6 3
Output power(dBm) 12 15
Attenuation(dB) 70 39
- 1142 hrs - at iPlate
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 6 2
- 1203 hrs - at master skt
ADSL
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 576 630
Noise Margin 7 3
Output power(dBm) 12 16
At master skt - 1218
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 6 3
1254 - At ext socket
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 6 4
1304 - At ext socket
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 7 4
My impression of these is that the system is basically sound and am wondering if the 6db we have been chasing is in a router rather than the wiring, I am sure the Linksys router was used when I found the 6db difference at the second ext second, I am afraid I am rather red faced if that aspect is a modem error. Do not want to put it in today and introduce a further service interuption.
It still remains why my speeds are so variable, as you commented my download speed is now about half what it was when we started, this reflects what I have been experiencing for about 7 months now.
Thank you once again for your understanding of a greenhorn
05-06-2013 5:27 PM
