Buffering with BBC iPlayer and general Broadband Speeds.
- Buffering with BBC iPlayer and general Broadband S...
Re: Buffering with BBC iPlayer and general Broadband Speeds.
16-12-2012 8:17 PM
16-12-2012 8:26 PM
Quote from: ReedRichards So your IP Profile remained the same even though the actual test results were widely different. Good to make sure of that.
That's interesting; I hadn't noticed that - With the IP Profile remaining the same but giving various speed test results; does this indicate a specific issue?
Thank you,
Kevin.
16-12-2012 8:42 PM
16-12-2012 9:39 PM
From the link you provided: my current line speed is 11.9Mb with Estimated at 11Mb.
I have attached a PDF of this information.
Thanks,
Kevin.
adie:quote
16-12-2012 11:14 PM
So that eliminates the third possibility of the four I listed in reply #5.
16-12-2012 11:45 PM
17-12-2012 3:49 PM
17-12-2012 8:38 PM
No I haven't.
I'd rather not do that at this time; my router is less than a year old and was perfectly fine with my previous ISP.
Can you tell me what Plusnet has done to try and resolve this issue?
Thank you.
Kevin.
17-12-2012 11:40 PM
18-12-2012 10:15 AM
Ex-Broadband Service Manager
18-12-2012 10:26 AM
18-12-2012 10:37 AM
As per ReedRichards reply; it hasn't been mentioned in previous posts.
Is there a test I need to undertake to find out or is this something Plusnet can find out?
If it is considered to be a congested exchange; what are my options?
Why would this be something we are only experiencing since our move to Plusnet?
Speed test results this morning are in the region of 10Mbps - however as per the attached BBC iPlayer Speed Test; their 4 readings are vastly different.
Thank you,
Kevin.
18-12-2012 10:41 AM
18-12-2012 10:58 AM
Thanks for the link.
I have attached screen shots of the results from the Exchange Checker, plus the details of the gateway I am on; (found in the link in your signature).
Thanks,
Kevin.
18-12-2012 11:03 AM
It would make sense to test it with a different router to eliminate it from the equation.
